Author Subject: A couple of things :-)
leddra2k
Hi all,
Now a proud owner of a 306 Rallye, just got a couple of quick question if anyone on them.
1. The interior light doesnt come on when opening the doors (with it switched to door mode) but if you switch the light onto (on mode) the light comes on, is there 2 bulbs under the panel or is it something else?
2. The airbag light continues to flash while driving, whereabouts does the cable run for this and maybe its a loose connection?
Cheers all!
D^
Posted 28th Feb 2010 at 17:10
scott.n
1. it could be the door sitch for the interior light as my passanger door one workd but my drivers door doesnt worth checking that .
2. Dunno if 306's are same as 106's but generally under the driver seat is a switch connected to the seats and if this is disconnected it throws up the air bag light flashing , might be worth checking its connected properly .
Posted 28th Feb 2010 at 19:11
leddra2k
Cheers Scott i'll check 'em out!
D^
Posted 28th Feb 2010 at 22:58
bonzo
This may be of use:Airbag FAQ
And it does indeed sound like the switches on the doors, both of mine have gone now, but occasionally give a flicker when the door opens.
Ninja Black Rallye Ninja
Posted 28th Feb 2010 at 23:11
leddra2k
Cheers Bonzo!
Posted 28th Feb 2010 at 23:30
puglife
It could also be faulty / corroded connections in the switch in the light itself.
Read the airbag FAQ, don't want it blowing up on you!
Back once again I'm the Moonstone Master :p
Posted 28th Feb 2010 at 23:33
leddra2k
The airbag FAQ looks the nuts will have to put some time aside next weekend for this Big grin
Posted 28th Feb 2010 at 23:39
bonzo
Cheers Bonzo!
Quite alright! Thumbs up
Posted 1st Mar 2010 at 00:30
