Author Subject: Crankcase breather problem?
puglife
My new 6 has a pipercross crankcase breather which seems to be smoking! Shock
Theres a pic below, as you can see the filter looks oily and seems to be letting off very light white smoke with engine running. I appreciate the oil may be burning off it, but any other suggestions? Is this common?
Piccy Clicky
The underside of the bonnet and some other areas appear to be coated in a mist of oil, but I'm not sure if this could be from when the previous engine went bang?
Back once again I'm the Moonstone Master :p
Posted 27th Feb 2010 at 21:49
I have an oil catch tank with that sort of breather on the top and it smokes a little from time to time and lets off a bit of a smell, nothing to worry about mate its just breathing off all the shit that would otherwise be being recycled through your inlet manifold and valves etc coating all the sensors and everything in shite.
Mine does it quite a bit because the piston rings are begining to get past it a bit and let a bit to much compression into the crankcase but expected after nearly 125k of thrashing Wink
Posted 27th Feb 2010 at 22:09
i'd sack it off and return it to standard, there's meant to be a valve there.
Posted 27th Feb 2010 at 23:17
puglife
I think I will. There's a fair bit of smoke coming from
the breather. I really hope it's nothing to worry about. There's also a noise coming from what seems to be just below and behind it. Any ideas on that too?!?
I'd be gutted if it broke!
Posted 28th Feb 2010 at 00:16
wont all taht shitty smoke go back in the engine then though?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 28th Feb 2010 at 00:44
yes/no, there is a valve inline, it'll only vent if the pressure gets too high I believe.
Posted 28th Feb 2010 at 00:48
puglife
Thats what I thought. I think tomorrow I'll give the filter and the general area a good clean up.
I'm more concerned about the noise to be honest. Sounds sorta like a tap, but it's only intermittent. Think that'll be a garage job, unless Carl comes along with any ideas!
Posted 28th Feb 2010 at 00:49
im sure when i had it off and blew thru it holding the other pipe also, it blew straight thru to the throttle vody.
Posted 28th Feb 2010 at 02:17
puglife
I'm just concerned about the smoke coming out of it!
Then again I got it cheap enough to pay for some repairs!!
Posted 28th Feb 2010 at 02:50
Unless your going to fit a breather catch can that works leave the standard set-up aloneWink
http://www.saikoumichi.com/OCC_explanation.htm
Cool
Posted 28th Feb 2010 at 03:34
joevts
noise sounds like a loose spark plug, i got that, on the same cylinder too LOL took the coilpack out and it was covered in soot Roll eyes
from what i've heard this 'valve' thing is just a load of wire woll type stuff, like in your breather filter Huh? and i really can't see the benefit of reattaching the whole thing and letting oil be sucked into your inlet manifold Huh?
Posted 1st Mar 2010 at 23:36
puglife
Ok, after further investigation, noise doesn't seem to appear if car is driven lightly, say below 3500rpm. Over this and it seems to make the noise. Possibly a sticky valve?
Worthwhile using an engine flush??
Ta!
Posted 2nd Mar 2010 at 14:26
