Author Subject: Heated rear windscreen
hudson603
Hi Guys,
When I try to turn on the rear windscreen heater I press the button in and the light comes on but as soon as I release the button it goes out and the window doesn't get heated? Any ideas? Had a look at the fuses and havent got a clue which one it is as I can't relate my fuse box to the one in the bloody manual!!! I know slightly retarded of me!
Steve
Posted 27th Feb 2010 at 21:20
puglife
Mine is doing exactly the same, hope to hear something soon!
Back once again I'm the Moonstone Master :p
Posted 27th Feb 2010 at 21:30
davet9887
mines kinda the same
i press mine in, while depressed the light, lights up fully then as i release it goes dim!
Then the windsreen only partially clears!
Posted 27th Feb 2010 at 23:11
cwspellowe
Tried a new switch?
Go to a scrappy, put one or two in your pocket Whistle
Bye bye Sundance Kid Sad
Posted 28th Feb 2010 at 01:38
puglife
I was thinking switch - maybe do a bit of scrapper stealing lol
Posted 28th Feb 2010 at 02:52
cress87
Switch. Yes
Posted 28th Feb 2010 at 19:23
hudson603
Really?? Oh bugger I've already swapped that panel over since I've had the car! Roll eyes
Posted 1st Mar 2010 at 17:27
cress87
If you can be arsed to sit around for a little while, hold the switch in and see if the screen warms up.
Posted 1st Mar 2010 at 21:36
tsangra
i had same problem. if u chek at the top of th windscreen there should be a plug on each side, they seem to go into the heatstrips. i found that one of mine wasn't actually connected and that fixed it
Posted 27th Jun 2010 at 04:40
hudson603
Nope, wasn't that Tsangra guess I'll have to try a button swap!
Posted 27th Jun 2010 at 22:33
rallye dave
i had same issue had a play with the relays by the fuse box unplugged them all one by one andi think the orange one smelt as if it was burnt changed it and heated rear window worked plus fag lighter kicked into life too
Posted 27th Aug 2010 at 03:36
hudson603
Well checked the orange relay and it didn't smell of burning and my lighter works so I don't think it's that, looks like i'll have to get a new switch to see if that helps?!
Posted 22nd Oct 2010 at 06:40
