Author Subject: torsion bar help
gtiniz
I am currently in the process of lowering my gti 6. Everything has went fine except the obvious problem of removing the torsion bars. As my 6 is a '98 phase2 the torsion bars seem to be siezed at both of the splined ends. I have tried various sizes of sliding hammers but they wont move, someone memtioned to me 'some heat' might help but i'm worried of causing damage to the bearings, seals ect. is this the case?
Any help or advice would be much appreciated, thanks.
PH2 NILE BLUE GTI 6
Posted 27th Feb 2010 at 02:33
at 12 years old I'd be changing them anyway Smile
Posted 27th Feb 2010 at 02:37
mechanical_repairs
It may be easier to strip the beam off the car so you can press the bars out. Whilst you are there you may as well fit new seals if the bearings are in good order.
Carl
Posted 27th Feb 2010 at 02:46
greenbelt
It is much easier to take the beam off if you have a press or to just remove the whole trailing arm for each side.
Support it on something sturdy (and fireproof), use a blow torch on the area shown below and get the persuader out Wink
It will free up eventually. Oh and new seals all round to replace the crispy ones LOL
Standard Black 6
Black HBSC6 Smoke
Posted 27th Feb 2010 at 03:16
jonnie205
both ends will probably be seized making it extremely hard to get arms off, use a porta power to removed arms then a press to get bars out of arms as they are usually stuck hard in the arms
Posted 27th Feb 2010 at 15:43
gtiniz
OK thanks folks Thumbs up
Will get stuck in today....Wink
PH2 NILE BLUE GTI 6
Posted 27th Feb 2010 at 16:55
gtiniz
Job done. Lowered 40mm on Spax springs Big grin
gtiniz has attached the following image:
PH2 NILE BLUE GTI 6
Posted 20th Mar 2010 at 02:16
mechanical_repairs
Good man, patience pays off in the end.
Mine on my car now greased to hell etc love to just pop out now which is good news.
Carl
Posted 20th Mar 2010 at 04:42
iplay
To allow torsion bars to come out time afer time use CS90 copper grease and some silicon on the retaining offset washer and around the torsion bar where it goes into the trailing arm assembly.
Posted 20th Mar 2010 at 13:49
