Author Subject: Subaru Brakes
kezman7
Quick question would a set of STI brakes fit on a 306? Im guessing brackets would be needed?
Posted 26th Feb 2010 at 06:19
yup, brackets and probably custom discs required, but I have seen a set of Alcon Prodrive brakes on a 205 Smile
Posted 26th Feb 2010 at 15:19
Are you talking about the 4 pot brembos? They are huge calipers mind.
Be careful of some of the early impreza brakes as they were shite.
Posted 26th Feb 2010 at 15:47
rallyestyle
Radial or lug mounted?
Just Drive It
Posted 26th Feb 2010 at 16:28
monkeyman
Check out replacement disk/pad prices before you go ahead, one poster on here said his cost
Forum Search Clicky
Posted 26th Feb 2010 at 16:40
kezman7
No i can get some Hi-spec 6 pots for a good price. 350mm.
Ill check prices out that never occoured
Posted 27th Feb 2010 at 05:17
kezman7
No sure thats them
Posted 26th Feb 2010 at 17:52
rallyestyle
They are radial Yes
Basically the only things in that kit that will be of use are the calipers and possibly the rotors Yes 350mm is massive so you would need big wheels to squeeze them under, decent 17's should do it.
How much do you want to spend to get these to fit?
Just Drive It
Posted 26th Feb 2010 at 18:45
rallyestyle wrote:
They are radial Yes
Basically the only things in that kit that will be of use are the calipers and possibly the rotors Yes 350mm is massive so you would need big wheels to squeeze them under, and the seatbelts will need uprating!
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 26th Feb 2010 at 21:31
kezman7
I know 17's are a must, my current ones have outward curved spoke so should be fine with them, Not sure how much i want to spend depends how much it WILL cost i supose. Whats the difference between Radial or lug mounted
Posted 27th Feb 2010 at 05:11
kezman7
Well they went for Skywards of 500 wonger so that idea's out the window Lol,
But still out of interest how much would you be looking at for the 4 stud inner part of the rotor and brackets to be made up to fit a pair of these? and would the Master Cylinder need uprating also?
Posted 2nd Mar 2010 at 01:01
rallyestyle
Well i got some ally brackets made up to fit my radials, they would probably cost
Just Drive It
Posted 2nd Mar 2010 at 14:50
