Author Subject: Bye Bye driveshaft
birk
Drivers side shaft cv blew up earlier Sad
Havent a clue what the shafts on the dimma are even from, anybody know if the bearings on the inner cv from a normal shaft will fit onto a dimma shaft ?
Dan
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 26th Feb 2010 at 04:45
simonjames
im 99% sure they just use a longer shaft and the joints are all stock
MY EBAY ITEMS
07943066306
Posted 26th Feb 2010 at 04:51
birk
Yea, thats what i thought aswell, the inner part of the drivers side shaft will be standard length, will just be the outer thats longer, although cant figure out what its off to make for easy fix if one ever breaks big time.
07889376885
Dan
Posted 26th Feb 2010 at 04:54
birk
From what ive just been trying to work out, i think the 1.9d expert van shafts might work with 306 cv's.
The shafts on the dimma are 40mm wider, well... at least i think they are, if this is the case, then the 1.9d expert shafts are 5mm longer on both side.
But we have no deffinate figures on how wide the dimma is, so they could poss be 45mm per side.
Might have to get hold of some and have a mess around.
07889376885
Dan
Posted 26th Feb 2010 at 05:15
kezman7
Bugger! Always a pain when there not common parts.
This mean you wont be at RR saturday?
Posted 26th Feb 2010 at 05:36
I think you have less luck than me with 306's LOL and i was p*ssed off my rear wiper fell off today LOL
Birk <---- quite clearly lives for the 306 :p
Posted 26th Feb 2010 at 06:32
hman205
the extra length on the wishbone is 40mm not sure on the driveshaft but im sure I have read up on replacement shafts for when I was looking at buying it. will get back to you
Another Broken one
Posted 26th Feb 2010 at 13:43
just get another 306 shaft and swap the fooked bits over, job done Smile
Posted 26th Feb 2010 at 15:09
anth
:p
Nice LOL
Posted 26th Feb 2010 at 15:10
LOL it literally did I walked over to it noticed it wasn't sat right touched it and it fell on the floor LOL
it's either some little twat with a football or it was just it's time LOL
Posted 26th Feb 2010 at 19:03
jib
Laugh my ass off good old frogs eh??
Posted 26th Feb 2010 at 21:29
rwgti
Gutted birk Sad
You not goin 2moro then?
Team Astor Grey Supercharged GTI 6
Posted 26th Feb 2010 at 21:46
birk
Fixed it Smile
The actual shaft was f*cked, all the splines have been chewed up when the bearing blew up.
So wasnt a simple case of swoping all the bearings and cv's over.
Cant tell you how i fixed it though Razz
07889376885
Dan
Posted 26th Feb 2010 at 22:57
BFH, welder + angle grinder?
Posted 26th Feb 2010 at 22:58
birk
New shaft Smile
07889376885
Dan
Posted 27th Feb 2010 at 03:40
cool, took the plunge and tried a pug van driveshaft then?
Posted 27th Feb 2010 at 03:56
birk
Whistle
07889376885
Dan
Posted 27th Feb 2010 at 04:08
dommo
Is that a phase 3 plastic wiper?
If so they're very flimsy! Mine wasn't wiping the rear windscreen very well so I had a look at it, pulled up that flap that covers the nut holding it in place and it was cracked under there, so I thought oh that's not going to last long, went to lift it up as you would when you clean the rear windscreen and it came off in my hand!
Seen a few phase 3 plastic wipers dangling down on some 206's and 306's. Seems those dangly ones are probably just held on by the flap that covers the nut/spline.
'99 306 Meridian TD with Bosch fuel pump - Cheap veg oil motoring
'99 Xantia Activa turbo - not cheap veg oil motoring Sad Goes around corners well though
Posted 27th Feb 2010 at 04:37
yeah that sounds about right well that last one lasted 10 years so
Posted 28th Feb 2010 at 08:09
