Author Subject: Head gasket
makie1199
Hi again guys, i need a bit help, (again) I need to get the head gasket done on the GTI-6 and i have been told i need head bolts, camebelt kit and water pump. I have been told buy an R.A.C. driver that the water pump is fine. so would i still need to replace this or can i use the old unit still? How much would you guys normally pay for a head gasket to be done? I have been qutoed around
GTI-6 owner and loving every second of it, apart from the scary ones!!!!!
BHP means power and with power you can rule the world!!!!
Posted 26th Feb 2010 at 00:24
How old is the water pump?
Basically you've got to consider that they do fail and when they do its usually expensive (valves etc).
Posted 26th Feb 2010 at 00:31
makie1199
Yeah the enigne will be re-skimmed and pressurised, but i do need to get head bolts, cambelt kit and maybe water pump. wot would you do use pump or not?
Posted 26th Feb 2010 at 00:55
smegal
Buy a new one. If it fails it'll f*ck the engine. Same goes for cambelt tensioners.
Ex SC-6
Now in a Megane R26
Posted 26th Feb 2010 at 05:41
head bolts are stretch bolts so you shouldn't use the old ones
You will need to change
Head Gasket
Cam Belt kit (belt, roller and tensioner)
Water pump inc metal gasket
Head bolts
Inlet manifold gasket
Exhaust Manifold gasket
Thermostat to head gasket
Thermostat and seal
A couple of cam seals will be needed
Check the rad as well suggest a new nissans ally rad
Hope that helps
Posted 26th Feb 2010 at 05:52
head bolts are not stretch according to my copy of autodata, but for the
Posted 26th Feb 2010 at 15:18
makie1199
Witch nissan ally rad fits? I am getting water pump, head bolts and cam kit now like you say if it fails its f***ed. I want to do it right the first time no cutting corners on this one.
Posted 26th Feb 2010 at 22:18
its nissens not nissan Thumbs up
Posted 26th Feb 2010 at 22:34
Depending on the age of your car or current rad, you may need a new bottom hose as well - there were a couple of changes to them and the Nissens rads use the later type.
Posted 26th Feb 2010 at 23:54
makie1199
What other upgrades are good to do? Any other tricks i should know about?
Posted 27th Feb 2010 at 03:31
