Author Subject: Cambelt snapped, now tapping
felixthecat
My cambelt snapped 2 weeks ago. There were 8 valves bent. We replaced all 16 valves to be sure. Now the car is tapping very loud, before the cambelt snapped it ran very smooth. Its sounds like a "click" click" "click". So we replaced 4 hydraulic lifters in the area where the noise came from. But its still there. I hope we didnt bent a new valve while fitting the head back on. Or maybe its just a bad oil? its a cheap 5w40 full synthetic.
Let me know what you think!
Cheers Felix
306 Gti6 Cherry Red Supercharged Smile
Greets from Germany....
Posted 25th Feb 2010 at 23:10
puglover Banned!
probably a damaged guide has bent your new valve. Sad
Posted 25th Feb 2010 at 23:14
cooper666
if im recalling corectly you will have valve guide problems sure its common on this engine when valves are bent
edit: to lateLOL
clio r27
ps3 id:cooperkloe
Posted 25th Feb 2010 at 23:16
pugjim
you could have bent the valves when you put the head back on/timed it up if you didnt do it right.
Posted 25th Feb 2010 at 23:22
felixthecat
Tomorrow i will do a compression check at work from wich i should see if a valve is bent or not. If the valve guides are damaged i need a new head right?
Posted 25th Feb 2010 at 23:53
Rich E Forum Admin
From my experience of timing belt failures you usually end up with most if not all valves bent. I reckon you've still got a slightly bent valve inside, or as others have said, have bent one during refitting / timing.
Posted 25th Feb 2010 at 23:54
chris with a pug
He replaced all the valves!!
Posted 26th Feb 2010 at 15:25
probably damaged guides and seats then.
Posted 26th Feb 2010 at 15:27
joevts
if the valves looked anything like this then you will be definitely needing some new guides
Posted 1st Mar 2010 at 23:53
felixthecat
*update*
now we replaced all 16 valves and 16 hydraulic lifters. Its still there Angry. When i start the engine from cold the first 20 sec you cant hear anything and then its getting louder...If the guides are damaged it should be all the time, right?
Posted 24th Mar 2010 at 22:52
how good is the oil pressure?
Posted 24th Mar 2010 at 23:17
lwgti-6
Are you sure you're fitting the head correctly and timing it up properly?
When i had a tapper, the tapping was very faint untill after 30 seconds or so then it became louder....
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 24th Mar 2010 at 23:29
cooper666
felixthecat wrote:
*update*
did you do the afore mentioned valve guides
clio r27
ps3 id:cooperkloe
Posted 24th Mar 2010 at 23:33
felixthecat
@ welshpug: dont know how good the oil pressure is but before the belt snapped it was good. Is the oil pressure affected by a timing belt snap?
@ lwgti6: Im pretty sure we timed it up correctly engine runs pretty smooth except of tapping.
@ cooper666: No, we didnt replace the guides.
BTW: Engine compression is perfect on every cylinder
Posted 25th Mar 2010 at 02:10
Felixthecat - You will need to remove the cylinder head and remove and inspect all 16 valves, and then inspect the guides.
I suspect all 16 valve seats will need recutting and you have probably bent a couple of guides. The tapping issue will not be hydraulic lifters, no point spending any more money on these. No
Stan.
Posted 25th Mar 2010 at 13:43
triky_6y
out of intrest what is compression on a gti6?
B-Road bomber
Posted 25th Mar 2010 at 23:16
rallyeash
what compression is your's? should be within 10 psi of each other ideally
309 3dr K20 Type R
Posted 25th Mar 2010 at 23:33
Guides need doing and yes they can be done just need to find somewhere that can do them Don't throw anymore money and the lifters or anything else as IT IS THE GUIDES
Wink
Posted 25th Mar 2010 at 23:43
felixthecat
Hmm but valves went in easily without any force and they didnt have any play. Thinking of getting a used head or a recon head....another few hundret bucks Sad. Is anyone interested in a tapping head with all new valves and lifters? Big grin
If i would find my damn camera cable i could post up a video.
Posted 26th Mar 2010 at 02:41
mike rallye
surely it be better to fix the head you got now? because you could by a second hand head and be in the same boat ,with same problem.
Posted 26th Mar 2010 at 03:15
mechanical_repairs
Fix what you have mate, you will have to remove it in any case, drop it to me if you like and i can repair it for you.
Carl
Posted 26th Mar 2010 at 13:23
Carl
hmm, Location: Schwanstetten Doh
Posted 26th Mar 2010 at 15:29
felixthecat
Yes, thats not that easy, i am from germany and shipping to you and back to me would cost around 150 bucks for sure but thanks for the offer Smile
Posted 26th Mar 2010 at 18:53
felixthecat
Another Update:
Engine sometimes simply stops running when rolling to traffic light and clutch is pressed. I have to restart it.
Posted 28th Mar 2010 at 19:54
