I'm considering it as an option for some bonkersness in the near future
| Author | Subject: sc'd s16 |
razzario
Junior User Location: cleckheaton Registered: 11 Nov 2009 Posts: 95 Status: Offline |
Anyone done it? will the standard lynx gear fit?I'm considering it as an option for some bonkersness in the near future |
Seasoned Pro Location: Parts for Sale section Registered: 04 Dec 2007 Posts: 7,442 Status: Offline |
I'm not sure if anyone has done it, or if it does fit, but I'm pretty much sure it will fit.________________________________________ Chris1999 China Gti6 Supercharged [Fun car] >>Project Thread<<2000 Bianca 306 Diesel [Work runabout] |
razzario
i've e-mailed lynx a few questions |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
Well the inlet from the gti6 fits the s16, so dont see why not.Not so sure on the ancillaries bracket though. ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
dan_s16
Seasoned Pro Location: Cheltenham Registered: 22 Jan 2005 Posts: 1,583 Status: Offline |
I've thought about doing it to mine but can't afford it.Although the engine mounts are different shapes the Gti 6 mount fits the S16 block so I can't see that being an issue. Infact I think your main problem will be the exhaust manifold. I just think it will be too restrictive. If you do go ahead with it though keep us updated as i'd like to see how it goes. ________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
cosmic spanner
Moral objector Location: North London Registered: 11 Oct 2004 Posts: 10,399 Status: Offline |
dan_s16 wrote: Infact I think your main problem will be the exhaust manifold. I just think it will be too restrictive. .. and the ECU would be a fair bit of work, I'd have thought? Unless you go to the GTI6 ECU (and relevant sensors, if they're different) & generic map.. or go aftermarket ECU.. ![]() ________________________________________ Democracy is two wolves and a lamb voting on what to have for lunch....Liberty is a well-armed lamb contesting the vote. Project é - my 306 project thread. |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
s16 will work in terms of kit fit![]() but ecu as cosmic says will be tricky. No one has maapped a s16 ecu for boost that i know of plus s16 has internal map sensor so throttle body mounting will be different. Rich is your man.. or contact wayne schoffiel at chipwizards.. ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
I have a maniflow exhaust manifold that will fit an s16 could maybe part with it for the right money |
soton_s16
Senior User Location: Southampton Registered: 18 Jun 2007 Posts: 703 Status: Offline |
bigbadbowen wrote: I have a maniflow exhaust that will fit an s16 could maybe part with it for the right money Does it include the manifold? ________________________________________ For all your Peugeot needs PugRacing.comGti S16 199bhp 164 ft lbs torques! |
Sorry I meant the manifold not the exhaust - my bad |
razzario
i have an omex 600 here from another project i could use, but having had a quick search i don't see why the gti6 ecu wouldn't go on there along with all its sensors and wiring (and it frees the omex up for the other car) |
allanallen
Seasoned Pro Location: Buxton Registered: 01 May 2007 Posts: 1,399 Status: Offline |
Doesn't the s16 use the same basic ecu as the xu10 8v turbo engine? I'm sure wayne can re-map those.________________________________________ www.bridgecraftmotorsport.co.uk |
soton_s16
bigbadbowen wrote: Sorry I meant the manifold not the exhaust - my bad Does it fit a 306 S16, or is it for a 205 conversion? If so, what sort of price are you thinking? ________________________________________ For all your Peugeot needs PugRacing.comGti S16 199bhp 164 ft lbs torques! |
I had it on my MI engine in a 306 I Believe the mi and s16 have the same stud layout ??? will think about the price, cost a lot as its the 3 part racing manifold with 2 ½ inch bore maybe get a pic up ? |
