Author Subject: Speedo stuck at 140!
willg
Randomly my speedo has stuck at 140mph. One moment it was fine then, reading 100, then 140 and its not moved since! Even if engine off.
I pulled the grey fuse, and only suceeded in setting off the alarm! Revs and everything else works fine. I'm guessing if the sensor was dead it would drop to 0?
So it more likely to be a bad earth? if so where are the earth points to check?
Posted 24th Feb 2010 at 02:55
birk
Begind the fuse box area next to the go go pedal on the right.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 24th Feb 2010 at 03:04
rizel23
i have this issue with my 306 (d turbo)
it has just had a new speedo sensor fitted and still no joy!
Checked earth by pedal fine as well as one by battery, what else could i try?
Posted 14th Apr 2010 at 00:49
chris167
try the earth next to the pedal LOL
There are currently 1 people online
Most ever was 173 on Sunday 9th Nov 2008 at 8:04pm
Registered Users: chris167
Posted 14th Apr 2010 at 00:11
