| Author | Subject: AIRBAG.know how needed |
mattgti^6
Newbie Location: BRADFORD Registered: 07 May 2009 Posts: 13 Status: Offline |
Is it possible to simply replace the airbag unit after is has fired or do you need to replace or reset the airbag ecu ??? thanks |
I'm fairly sure you have to replace the ecu as well. Worth asking your local dealer if the ecu needs resetting though as i'd have thought they'll know.Don't forget about the seatbelt tensioners... ________________________________________ Nothing to see here |
birk
Seasoned Pro Location: Doncaster Registered: 24 Oct 2005 Posts: 7,032 Status: Offline |
I think you have to aswellI have airbags and ecu's if your interested. ________________________________________ Dimma + Gt35 turbo =![]() Solid rear beam mounts £130 07889376885 Dan |
mattgti^6
Yes is a 1 time deal once fired you need to replace ecu aswell. Think have sourced bags and ecu but may get back to you if have any probs or blow them up trying to fit.\Thanks to all. |
