Author Subject: ABS light
rallykid
Since the demise of my rallye i have been pottering around in my HDI. But the abs light has started to come on, I have done all the usual checks to the braking system to find nothing wrong with it,When the light is on the abs still works fine. Has anyone else had this problem and managed to fix it ?????
Cheers phil
Posted 23rd Feb 2010 at 02:54
ablister
have you checked sonic rings on front driveshafts, common for them to break
306 rallye, Richard Longman engine
rc10gt
Posted 25th Feb 2010 at 00:48
rallykid
Yes checked them, That was one of the first things i checked out, I have just done the earth points to no avail to. Angry
Posted 25th Feb 2010 at 23:17
harny86
the sensor mate u checked that?
Posted 26th Feb 2010 at 00:10
rallykid
Yes checked all sensors they are behaving as they should do, Ive put brakes on hard when the light is lit and the abs kicks in as it should. I have tested sensors and all are working fine, The only thing left to do now is a fault read on them.
Posted 26th Feb 2010 at 03:00
monkeyman
Check the brake pad wear cable that runs from the pad to a plug somewhere on the brake housing. It is a simple circuit that completes when a metal pad in the brake pad makes contact with the brake disc and gives you a warning light when pads get near to replacement. You can get a false earth because the cable insulation has been cut or worn through and is making contact with the inside of the wheel rim, or another metal part of the suspension.
Forum Search Clicky
Posted 26th Feb 2010 at 16:51
