a - Does the immobiliser stop the pump priming?
b - Does the crank sensor stop the pump priming?
c - Will the GTi engine and loom happily run an XS pump?
Car is xs converted to vts with gti loom, ECU is unlocked, earths are good as far as I know, and bridging the relay on the back of ecu box didn't start pump, revs aren't shown on counter when cranking. There is also a double click on 2nd ignition from around the ABS unit and a single click from 2nd to 1st stage.
Any help would be much appreciated need this back on the road asap.
Thanks
There are only 10 kinds of people in this world, those that understand binary and those that don't...
funkymonk
