Author Subject: Drill out or not?
richie_25
As above im wondering should I just drill out the little bolt that holds the disk in place once the wheel bolts are out? They are solid and ive already broken a T30 trying to loosen them but they just wont budge.
I guess the lifetime warranty on my Halfords socket set will be used sooner than I thought especially since I just got it on Sunday!
Posted 22nd Feb 2010 at 20:23
jon kirby
Yes drill it out Wink
Posted 22nd Feb 2010 at 20:25
they shouldn't be that tight, though a manual impact driver will help.
720puggti
I find if you hit them with a hammer they usually crack off with a sharp jolt using using the t30 socket on an extension... I find it's all down to technique rather than power.
Deepak Gohil
Posted 22nd Feb 2010 at 20:51
jim01uk
tried a penetrating fluid on them? or a bit of heat?
I have started using this:
and its f*cking awesome. we have some nuts/bolts etc at work that are 30-40 years old and never been released, this stuff does the trick every time!!
Posted 22nd Feb 2010 at 20:59
rallyestyle
Where do you get that from Jim? Looks like it could be very useful to keep in the shed!!
Just Drive It
Posted 22nd Feb 2010 at 21:07
jim01uk
work Whistle
Posted 22nd Feb 2010 at 21:21
rallyestyle
jim01uk wrote:
work Whistle
Useful Roll eyes Razz
I will have to track some down Yes
Just Drive It
Posted 22nd Feb 2010 at 21:26
al4x
surely though making them colder makes them more brittle and prone to snapping
Posted 22nd Feb 2010 at 21:29
kezman7
Just drill it out, Not really needed just helps abit when fitting wheels to stop the disk moving over the holes
jim01uk
not in our experience! But even if it did in this case, the OP wouldn't have lost anything if he was planning to drill anyway!
Posted 22nd Feb 2010 at 21:38
freezing the fastener quickly shrinks them and breaks the seal of corrosion.
Posted 22nd Feb 2010 at 21:41
Same works for localised heating if you have access to some oxy/acetylene cutting gear Wink
Posted 22nd Feb 2010 at 21:43
richie_25
Well in the end I just drilled it out. However it seems that was just the start of my problems! The slider bolt heads are so corroded that they will not release either and the 13mm socket and spanner just turns on it. Tried a half inch one too but same story. Anyone know any ways I could free these? Maybe a 6 sided socket rather than a 12 would help?
I did try taking the whole caliper off but when I fit the new pads and disks there simply isnt enough room for everything so I reckon the sliders need freed so I have a bit more space to get everything on again Sad
This day has been one problem after another, im off to have a beer I think (certainly dont need to worry about driving the car!)
Posted 22nd Feb 2010 at 22:40
jim01uk
I'd probably try gripping the heads with mole grips as they shouldn't really be that tight, other than the corrosion. 35FtLb with threadlock on.
Posted 22nd Feb 2010 at 22:52
smighall
Smeg-all
You are putting a 17mm spanner on the slider part aswell as just the 13mm bolt aren't you?
Meh
Posted 22nd Feb 2010 at 22:54
richie_25
Using Welly's FAQ it seems its not necessary until the bolt actually starts moving. The only movement is the socket or spanner rounding it off. Might thump a 12mm on and use that, unfortunately both sliders are the same and I have a fair idea the other side of the car will also be the same too. Grr.
Posted 22nd Feb 2010 at 23:02
smighall
Smeg-all
You may be able to cheat a little, if the 13mm is rounding off, give the 17mm a thump on the spanner, may well be enough to break the theadlock / corrosion etc.
Meh
Posted 22nd Feb 2010 at 23:05
i use a impact driver on them little disc screws. i havent had a problem removing any since i got it years ago.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 22nd Feb 2010 at 23:25
