Author Subject: Hunting/Stalling
Boab
Recently changed my Lambda sensor (for 2nd hand one) due to overfuelling. Was working fine to start with but now i have a problem when starting from cold.
On first starting the rev needle doesn't move for at least 5-10 seconds then jumps up, if i don't keep the revs up the car will stall on me. Also when pulling away, especially when i get to 2nd,3rd or 4th gear the car hunts a lot until warmed up.
Is this the Lambda or is it the ICV which has been suggested to me already?
PH3 Team Astor™GTi 6 owner
Posted 21st Feb 2010 at 22:33
iplay
Do you have an exhaust leak between the exhaust manifold and the catalytic converter? Could be that the firing ring has disintegrated and lets air into the cat effecting running until the manifold warms up and seals it tight?
OT: I am moving house soon ... do you have any more super sky deals? Whistle
Posted 22nd Feb 2010 at 05:19
Boab
I don't think so but i am getting strong smelling exhaust fumes now so will look into that.
I'll PM you about sky later mateWink
Posted 22nd Feb 2010 at 14:15
justinaccurate
I'm thinking maybe MAP?
Posted 23rd Feb 2010 at 00:22
greenbelt
MAP sensor Yes
Does the car kangaroo when you gun it?
Standard Black 6
Black HBSC6 Smoke
Posted 23rd Feb 2010 at 01:03
Boab
greenbelt wrote:
MAP sensor Yes
it does mate, will try that first then. cheers guys
Posted 23rd Feb 2010 at 02:26
Boab
Ok going to finally get round to sorting this problem out at weekend. quick question, can i clean the MAP sensor in anyway or does it have to be replaced?
I'm also going to clean stepper motor and check the coolant temp sensor. How is the best way to test the temp sensor?
Posted 11th Mar 2010 at 21:21
Boab
Right, had a bash at this today. Got ICV/stepper motor out and cleaned it with WD40 inc the housing.I also checked connection for the temp sensor. Took the Map sensor off but had no idea what to do with it so put it back on Laugh
After completing an ECU reset i have found the hunting seems to have gone. I only now have an issue on first start up where the revs jump over 1000 rpm then drop to almost a stall then go back up and settle on 950 rpm.
Any further ideas on this?
Posted 16th Mar 2010 at 19:18
scott.n
Mines still sometimes does this and i have changed , map , stepper , cleaned other sensors etc lol still no joy with mine
Posted 16th Mar 2010 at 20:50
:: blade ::
had the same prob with mine, just done a ECU reset and cleaned all the sensors, so goin out for a drive in a min to see if all is well Smile
Black Ph1 XSi-6
161.8BHP (Getting Better!!!!)
Posted 17th Mar 2010 at 01:24
justinaccurate
Try disconnecting the plug from your throttle position sensor. They run fine without it; just revs a bit higher on start up, its free to try. Might need a mirror to see where it is tho (big white thing on the underside of throttle body)
Posted 17th Mar 2010 at 01:37
kit
I would replace the ICV. If you have cleaned your current one it may well be knackered beyond use.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 17th Mar 2010 at 04:08
:: blade ::
well been for the drive, and all went well, usually its starts doing it after 10 or so mins, lasted a lil longer this tims and did it after about 30mins, but doesnt stay as long, then will go, then 5mins after will do it again :S, ive changed the icv,
Black Ph1 XSi-6
Posted 17th Mar 2010 at 04:15
Boab
Thought i would update this.
Looks like the Map sensor was the culprit.
Got one from CUJ on here and replaced it today, done an ECU reset then went a drive and no stalling at all. Was even trying to make it stall and it didn't Big grin. Hunting seems to have gone completely too.
Cheers for all the help Thumbs up
Posted 4th Apr 2010 at 00:44
