Author Subject: XSi won't start after 2 years in garage..
xocekim
It has not been looked after at all, just sat for about 2 years with no starts etc. I know im naughty Sad
Ok so battery is dead for a start, hooked it upto our car and electrics work fine (battery is not holding a charge either). Coolant was empty so topped that up, doesn't seem to be leaking. Put some WD40 on the cables around and about. Oil level is ok I guess it could do with a change though lol.
When I try to start it turns over but it is not firing. The engine management light is always on and so is the "STOP" light. There is still petrol in it but not sure what that is like after 2 years?
The battery is dead in the key fob.. doesn't need that to deactivate the immobiliser does it? Is this an immobiliser issue?
Is the next step to change the spark plugs?
Any guidance would be appreciated. I will most likely get a garage to look at it soon if I have no luck myself. Thanks.
Posted 21st Feb 2010 at 21:56
cress87
The petrol won't be much cop after two years. No
Try some fresh fuel first.
Posted 21st Feb 2010 at 22:00
simonjames
Oil presure need to build up for the hydralic lifters to open how long do you turn it over for?
when you turn the ignition on do you head the fuel pump prime?
MY EBAY ITEMS
07943066306
Posted 21st Feb 2010 at 23:01
