Author Subject: windows/central locking dead
bonesy_1
hi got a problem with my electric windows and with my central locking im sure they are related, from the start, both where working fine (the locking on the foCooland the windows on all buttons and all doors UNTILL it went for mot it passed and we headed home went to close the drivers window which the garage had opened because they do,nothing happend i suspected a fuse, it wasent. so now my suspicion moves on to the small electrical box in the drivers door(which contains a printed circuit board) which clicks when i attempt to open/close the drivers window. does anyone know exactly what this box does and is called as i assume it controls the windows, and maybe the central locking as there is no response from either the fob or the lock. any help would be much appreciated, many thanks in advance andy
Posted 18th Feb 2010 at 01:46
ste-sim
You need to check the loom between the driver door. Cut open the rubber cover and see if any of the wires are broken and if so repair with solder and heat shrink.
http://www.306gti6.com/forum/showthread.php?id=50366&page=1
Posted 18th Feb 2010 at 02:50
bonesy_1
would this cause my whole window /cl system to completly fail? will the wires be oviosly broken or is this a tester job?
Posted 18th Feb 2010 at 03:55
ste-sim
Yes if the wires that control the windows are broken then your windows won't work as for fixing the wires all you need to do is join the wires back up to the right colors and your windows and c/l will be fine.
Posted 18th Feb 2010 at 03:59
bonesy_1
you make it sound like paint by numbers lol,what exactly am i looking for are you talking full on cable in half, or a sneaky i dont look broken but i am wire?
Posted 18th Feb 2010 at 04:04
ste-sim
Under the rubber cover will be a bunch of coloured wires just look through them and repair the ones that are snapped. simple as that
Posted 18th Feb 2010 at 13:53
bonesy_1
thanks for the help i will have a go tommo eve or saturday dependent on the weather. let ya know how i get on. andy
Posted 18th Feb 2010 at 23:42
bonesy_1
update
i looked at the wireing today was all in good order, have to say i think its the little black box containing the printed circuit board inside the door card. so i am after a new/used one to attempt to fix my problem, does anyone have one? i have paypal. andy
btw it is a '97 'r' reg i belive a phase 2?
Posted 21st Feb 2010 at 00:42
