Author Subject: ABS sensor removal
iplay
Can I unplug the front ABS sensor and drive the car without warning lights etc?
Posted 16th Feb 2010 at 04:14
cosmic spanner
Moral objector
No sorry if a sensor is disconnected it will log it as a fault and the ABS warning light will come on (and no ABS, but you can still drive the car obv.)
Democracy is two wolves and a lamb voting on what to have for lunch..
..Liberty is a well-armed lamb contesting the vote.
Project é - my 306 project thread.
Posted 16th Feb 2010 at 04:33
iplay
If I drive the car and then reconnect a new ABS sensor will it clear the fault code or would it require fault code removal by Peugeot?
I was fitting a new top mounts, hubs, struts and dampers and the old ABS sensor would not come out Angry
Posted 16th Feb 2010 at 04:49
smegal
If you replace the sensor and unplug the battery it will clear the code, well it will at remove the ABS light on the dash (I needed a new sensor on mine when I got it and the light went away with a replacement).
Ex SC-6
Now in a Megane R26
Posted 16th Feb 2010 at 04:53
cosmic spanner
Moral objector
Yeah you can either disconnect the battery, or I've been told after "a number" of ignition off/on it will clear logged faults as well... but AFAICS every time you fire it up, the ABS unit checks the status of the sensors - if they check out OK, then it should be happy.
Posted 16th Feb 2010 at 05:44
Rich E Forum Admin
You don't even need to disconnect the battery. The fault will clear when a good signal is received from all sensors at above 8mph.
Posted 17th Feb 2010 at 21:31
smighall
Smeg-all
As Rich says. Hence why whenever you put a car on a RR you'll get the ABS light on indicating a fault as the fronts have been spinning and the rears stationary so it thinks the rear sensors are f*cked.
Meh
Posted 17th Feb 2010 at 21:40
