The feed will be 10mm and the return will be 8mm, not sure if that matters.
Cheers in advance
| Author | Subject: Fuel pressure gauge |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
I am wondering if its ok to put a fuel pressure gauge in the return line instead of the Feed.The feed will be 10mm and the return will be 8mm, not sure if that matters. Cheers in advance |
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,868 Status: Offline |
bit pointless putting it in the return......________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
chris with a pug
why? |
think about it....the return line will have hardly any pressure in it whatsoever, especially on WOT at higher revs ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
what gauge you using and what kind of sensor will it need to fit in the line?________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
chris with a pug
that is why i am asking!!I wasnt sure if there will be a pressure drop or not. |
chris with a pug
Its a mechanical RMD gauge. The reason why I am asking is I worked out what aeroquip connectors I needed a few weeks ago and ordered the bulk head fittings so I could drill them and fit them, but when I got them I put the weld on ends against the fuel rail and saw that the return is onyl 8mm, so if I use 8mm for the return, 1 it will cost less and 2 will give me more room for the weld on fittings on the fuel rail and will make it easier to weld. I was looking at buying a bulk head t- peice to run the gauge and ordered 3 8an(10mm) bulk head fittings as Alex doesnt stock the t-piece bulk head fittings, so instead of having to sell 2 8an bulk head fittings, if I could put the gauge in the return will mean I can utilise what I have. |
vts_gav
Regular Location: Redcar Registered: 12 Jun 2009 Posts: 367 Status: Offline |
mine is plugged into the spare port on the supply side of the fse thing i have so i could get exact pressure when fitting it |
pdd144c
Senior User Location: Southampton Registered: 09 Dec 2005 Posts: 550 Status: Offline |
Has to go on before the reg Chris.________________________________________ FOR SALE205 Turbo Technics complete and 306 Rallye Race Build breaking. |
chris with a pug
Ok cool, thanks.Anyone need any aeroquip bulkhead fittings or a weld on end? |
