displaying posts 1 to 2 of 2
Author Subject: Parts needed for converting ignition for aftermarket ecu?
devere
Just wondering what parts i would need to convert my Rallye from the individual coilpacks to a single. Want to make things simpler and easier for troubleshooting if anything ever crops up while rallying.
Im also wanting to get an OMEX ecu in the near future and know i kind of need to use a different set up. Is the 106 ralley coilpack the one to use..?
And also, whats required for changing the plug, to plug in to the new coilpack?
I did a search but couldnt find any information on this really. unless i didnt search the right terms! lol.
Cheers.
Posted 13th Feb 2010 at 00:46
you can't change to a single coil pack without changing the ecu for an aftermarket one as it runs a sequential spark not a wasted spark.
Its easy enough to trace a fault with a coil pack, you get a misfire, unplug it and if you get no change in the misfire that's your faulty unit, simple diagnostics Smile
As these are not that common a fault I would stick with them as they do away with the need for ignition leads or a remotely mounted coil pack.
I saw that Miles commented that the Emerald ecu can handle the 4 individual coilpacks as standard, the basic Omex doesnt handle this and you'd need to go to the 710 ecu which costs a bit more.
Posted 13th Feb 2010 at 01:15
