Author Subject: driveshaft play
stiff
have been trying to place a problem(see droning noise sorted thread) and have jacked up pug and with car in first turned wheel back and forth to see if theres play in shaft, my question is how much play should there be ? and is there any other way to check this ? i have tried turning wheel in neutral to check for clicking noise and there is none on either side ,(read that here on forum) any help greatly received ,
cheers
stiff
STIFF
Posted 12th Feb 2010 at 14:55
phippsy
I wanted to ask the same thing, i've been looking and checking for wear and tear before and drive shafts are next on my long list of things to think about replacing.
I took the n/s wheel off to have a look the other day with the car in first, turned the disk gently until it stopped (about 1 inch or so) then tried turning a little more as I was under the impression that's where the 'play' was. Mine move less than 1mm but I wasn't sure what I was looking at was the right thing...
Posted 12th Feb 2010 at 15:03
stiff
well have had pug of misery up on jack in drive way had the wheels off and cant see nuthin obvious , drivers side drive shaft in gear without wheel turns about a quarter to half inch ,passenger ones about the same so dont know if thats more than it should be ?????
anyone please?Crazy
STIFF
Posted 12th Feb 2010 at 20:54
stiff
forgot to say there doesnt appear to be any play if i try and pull and push them towards the wheels or back again,
STIFF
Posted 13th Feb 2010 at 22:18
