Author Subject: Bitron unit wiring
funkymonk
Just a quick question, where does the connector for the bitron unit come from? Does it join with the main engine loom directly? I have done a search and couldn't find what I wanted, I have just put an XU10 into my XU7 w/o aircon shell and so had no external fan controller before and can't find anywhere on the loom to connect the bitron from the donor, hope that made some sense to someone!
There are only 10 kinds of people in this world, those that understand binary and those that don't...
Posted 11th Feb 2010 at 22:00
dan_s16
I'm not 100% sure but I think it's on the main loom that goes under the radiator and up the side (after the engine loom connectors) it carries on upwards into the wing and that's where its all wired to but it's been a while since I had the bumper off and was messing about with the loom on mine.
Posted 11th Feb 2010 at 23:27
mabgti
NV motors
Its under the nearside front wing.. held in by two 10mm bolts.
It then runds along the front crossmember iirc.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 11th Feb 2010 at 23:30
funkymonk
Ok so it should be coming off my loom but isn't? What does the rallye run as it has no AC, still a bitron unit? Anyone know how to get my fans working ? Unsure
Posted 12th Feb 2010 at 00:36
pugheaven
Can you not hard wire them in with a switch. Then you can put the fans when ever you like.
Posted 16th Feb 2010 at 21:36
I wouldn't bother with a switch.
which fans and rad have you used?
the rallye is a non-a/c setup which uses a thermoswith in the rad, should be the same as your 1.8 in that respect.
Its totally separate to the engine loom however so you wont have any issues with it being a gti6 engine loom.
Posted 16th Feb 2010 at 21:41
funkymonk
Cheers Welshpug, hopefully it will work ok then. If I can get it started at all Sad see other thread!
Posted 22nd Feb 2010 at 23:07
