The heater pipes in particular how do i fit these? chop the bulkhead connectors off the originals and use a joiner? Any help appreciated
| Author | Subject: s16 samcos |
razzario
Junior User Location: cleckheaton Registered: 11 Nov 2009 Posts: 95 Status: Offline |
The heater pipes in particular how do i fit these? chop the bulkhead connectors off the originals and use a joiner? Any help appreciated |
dan_s16
Seasoned Pro Location: Cheltenham Registered: 22 Jan 2005 Posts: 1,583 Status: Offline |
The original pipes have a plastic collar moulded around the pipes. If you very carefully cut through this, you can then pull the pipes off and be left with the fitting for the bulkhead ready for the samco pipes to connect to with jubilee clips on them.Does that make sense? it's hard to explain but fairly easy to do if you take your time. If it helps I can get close up pics of mine but I don't really want to be taking it apart. ________________________________________ When I've got time I forget what I wanted to do, and when I remember what I wanted to do, I have no time! |
razzario
makes perfect sense... cheers mate |
