displaying posts 1 to 1 of 1
Author Subject: wont go into gear!!
jamie192
Hello all again,
This is not about my 6 this time, my offroad toy, got a jeep cherokee.
Its got a hydraulic clutch. just replaced the master/slave cylinder. But when on a standstill if you put the clutch in and try get into first - 4th gear it just will not go, when trying to get it into reverse you can hear the gears grinding and eventually stops then will go into any gear. but as soon as the clutch is lifted then put back down it wont go in gear again untill u grind reverse.
Any ideas on what it could be? A
sking you guys because you tend to be quite the mechanics Smile
Goes into gear fine when changing through gears. Just at a loss of what to try next. Some people say make sure the gear box oil is up but this sounds like the clutch is dragging to me?
Thanks for looking Smile
Posted 7th Feb 2010 at 03:46
