Author Subject: Starting problem
tommy
My Xsara VTS seems a bit reluctant to start most mornings when it's been stood overnight. It always does start within a couple of seconds and runs perfectly afterwards but it feels like it bogs down on the first revolution before starting on the 2nd or 3rd. It's not a battery issue, it has a newish one and it doesn't feel like that, it's more like it's a fuelling thing like it takes a second to sort out the correct mixture or somethingCrazy
It's kind of hard to explain and it's not a big deal at all as like I say, it always starts but I'm selling it soon so whilst it's never bothered me that much it probably would bother a potential buyer! Any ideas what could be causing it? Stepper motor issue maybe?
Xsara VTS - Warm and dry
Honda CBR600F3 - Cold and wet but...0-100 in 7 seconds Big grin
Team "I had a TZR125™"
Posted 7th Feb 2010 at 01:27
ever done a compression test or taken the plugs out?
do it cold after leaving the car overnight.
mine did this and it was the headgasket...
Posted 7th Feb 2010 at 01:34
tommy
Shit, that's worryingUnsure And there's me banging on about it being no big dealLOL
Was that your only symptom though? As I say, it runs fine otherwise and isn't down on power? Doesn't seem to lose coolant or anything either.
Posted 7th Feb 2010 at 15:29
tommy
Ok, finally got round to doing a compression test and it was fineHappy I've also noticed that it doesn't do it when you turn on the ignition and then give it a few extra seconds before starting it, have I accidentally bought a dieselLOL
What might be causing that? It's got me stumped.
Posted 24th Feb 2010 at 14:51
dannyb1
Are you letting the fuel pump prime before you go over to third click , or are you a key in and ram it right round to start kind of guy ?
If so its pretty acceptable for it to not fire right away as it will have zero fuel pressure until the pump has primed.
You want tact ? Call a tactician !
Xbox 360 : Cableguy1984
Posted 24th Feb 2010 at 14:56
tommy
Well, I don't start it THAT quick I don't think; it's sort of hard to picture it now but whatever I've been doing has worked for the last 10 years! I wonder if the fuel pump is taking slightly longer to prime than other cars I've driven so I'm noticing a lag?
Posted 24th Feb 2010 at 15:21
