| Author | Subject: Quick rev counter question |
rallye1999
Location: redcar Registered: 05 Jul 2009 Posts: 722 Status: Offline |
My rev counter packed in the other day so have done a quick search and seems it's quite common, I tried swapping the fuel pump relays between both my 306's but the problem is still there so I'm guessing the relays are both ok, fuses are all fine, would this be a fairly simple job for a auto electrician as I m pretty useless with electrics, |
rallye1999
also a couple of days previous to rev counter failing the fuel pump constantly primed (ok now) and idle held at 3k when started it up, shut it off and re-started it then jumped from 1-1.5k (now its ok also)i might swap the clocks over but failing that could the ecu stop the rev counter working? |
rallye1999
Just wonderd if a rev counter could be directly wired in and bypassing the loom? I was thinking it might be possible to do it the same way as 205 conversions by bridging the coils, would the rev counter accept the signal or is it a different type of signal? |
rallye1999
Changed the clocks, ecu, crank sensor and fuel pump relay, checked the big plug behind rad and ..............nothing lol |
gnrlee
Forum AdminLocation: Leeds Registered: 20 Aug 2005 Posts: 8,891 Status: Offline |
are you sure the clock's rev counter was working on the new clocks? did you see them working?apparently it can be down to the solder on the back of the circuit board i re soldered mine and painstakingly re-built the little white motor,.. now it just twitched on turn over and turn off ![]() ________________________________________ Proud Member of the ASTOR Owners Club |
rallye1999
gnrlee wrote: are you sure the clock's rev counter was working on the new clocks? did you see them working? apparently it can be down to the solder on the back of the circuit board i re soldered mine and painstakingly re-built the little white motor,.. now it just twitched on turn over and turn off ![]() yeah they work as ive got two rallyes and kept swapping bits over, ive given up at the moment and am building a set of clocks myself, hopefully with central rev counter and oil preassure and oil temp, water temp and fuel level, going to use an autogauge 9117 adapter to get the tacho working |
