Author Subject: hydraulic lifters
spaniel
i gotta fit a set of lifters tomorrow, they have arrived but they do not compress as they are ment to. i know that when you re-fit tappets your meant to drain the oil but i have been told as they are new they should be ok to go straight in and the pressure of bolting the cams in will free them up. am i right or do they need to be drained. i need to know asap. cheers
Posted 6th Feb 2010 at 00:01
I do hope they are o.e, what was your reasoning to change them?
Posted 6th Feb 2010 at 00:04
stealthcossie
are these a regular thing that go on the 6's as i've not heard much about them on here??
Dave
Posted 6th Feb 2010 at 01:26
chris with a pug
I am not sure if this helps, but when I stripped my head I had to compress some of the lifters with a g clamp.
Obvioulsy they arnt new ones but might help you out.
I have always been told to compress lifters before fitting, but again not sure if that is just for used ones, have you asked the supplier
Posted 6th Feb 2010 at 01:38
spaniel
yeah i talked to them but they weren't much help, i don't think they know what they are talking about. been trying to tak to a pug mechanic but they haven't got back to me
Posted 6th Feb 2010 at 12:54
chris with a pug
PM mechanical repairs he might be able to help you.
Posted 6th Feb 2010 at 13:55
Why are you changing them? I can't remember anyone ever having issues with one breaking before.
Posted 6th Feb 2010 at 14:26
spaniel
it all started with the head gasket going, i did this at work with some help from the fitter. the first time i did it it was really noisey. i did a bit of reading and found out that you have to drain the lifters. so i took it apart again drained the lifters as the manual said and when i put it back together it sounded better but still noisey on a couple of the lifters.
so i decided rather than messing about with the original lifters to just put in some new ones and get it back on the road.
i have just done it today and its still not right. its better but its got a bit of a tapping noise coming from the rear cam. also when i drove it out of the garage and round the corner (on low revs) a couple of times the revs dropped to about 200rpm. i kept my foot on the clutch and let them come back up. i really don't know what to do know, a mate has suggesting re setting the ecu. any ideas?
Posted 6th Feb 2010 at 23:54
Perhaps you 'nicked' a valve when putting the head back on and now it is slightly bent which is causing the tapping?? Unsure
Stan.
Posted 6th Feb 2010 at 23:58
spaniel
it could be i'm not suere how much it would take to bend a valve i woudn't have thought it would be that easy. i'm getting really fed up with it now. any one else got any ideas
Posted 7th Feb 2010 at 15:04
rich_w
My money is on a mildly bent valve that isn't seating properly.
The lifters on these engines are very reliable. It's not essential to drain them, but recommended if you've done anything to alter the clearance between the tip of the valve stem and camshaft lobe.
i.e. re-cut the seats or fitted different cams.
Re-setting the ECU won't do anything.
Contact Details:
07732 822546
Posted 7th Feb 2010 at 15:59
they only have 6mm stems, they bend very easily Sad
Posted 7th Feb 2010 at 16:08
spaniel
i had a suggestion today from a mechanic that the oil feeder pipe from the sump could be partly blocked and it is not allowing all the lifters to fill up. is it worth checking this because i would of thought that the oil would eventually get through to fill them as it has been run for about 10 min
Posted 8th Feb 2010 at 23:37
extremely doubtful, there's a gauze filter on the end of it.
is your oil pressure warning light on? if not it discounts the theory above, I doubt they'd run for a whole ten minutes without oil going round the bottom end bearings either.
Posted 8th Feb 2010 at 23:40
spaniel
ok fair enough looks like its going to a garage
Posted 9th Feb 2010 at 22:51
mike rallye
i got the same noise as you, i got tapping noise and bean told it a beant valve, so am taking it to carl tomorrow to have a look at and fix it
Posted 10th Feb 2010 at 02:23
