Author Subject: 1.9 205 gti mixing oil and water !!!!!!!!!
Paddy Power Turbo Banned!
i have just done the head on my 205 gti and its still mixing oil and water Wink what else could be causing this problem ???? would it be the seals on the liners or would it be a crack in the block ????
please help me out guys im going mad trying to get this sorted so i can sell it
TEAM(FIGHTIN IRISH)COMIN TO A PUB NEAR YOU !!!!
ps3 online name : butcherboy200
dyno print out : 185.4 at the flywheel
modern warfare 2 Wink
Posted 5th Feb 2010 at 04:07
anyone got any sugestions of what mught ov happened
Posted 5th Feb 2010 at 05:30
jonnyboy17
cracked block i would asume as the headgasket been done..
asuming you skimmed the head when fitting it, or put new one in?
Team Dirty Black... Formerly Known as Astor
sharland wrote:
When women don't behave like they do on brazzers.com in real life it disappoints me.
rikky wrote:
the day i own a credit card is the day i saw my helmet off and fire it from a potato cannon
Posted 5th Feb 2010 at 05:33
ya i skimmed the head and got it preasure tested all the valves and everythig done i have a spare block but the liners are rusty in it shud i use my own linersSad
Posted 5th Feb 2010 at 15:54
ryangti6
When you refitted the head did you measure the liner protrusion and make sure they were within the limits?
Are you getting a lot of pressure in the cooling system or just noticing the oil/water mix?
If its only the water and oil mixing then flush both out as good as you can, it's possible you still have a bit of oil in the water or vice versa from the first time the gasket went.
Ryan
Posted 5th Feb 2010 at 16:32
probably liner seals Sad
Posted 5th Feb 2010 at 17:47
i didnt do it i paid a mechanic to do the head thinking it would solve the problem but no... its still mixing whats the best solution ????? shud i changer the block ?????
Posted 6th Feb 2010 at 07:13
Have you got a heat exchanger fitted to the engine??
Have known these to leak internally. Yes
Stan.
Posted 6th Feb 2010 at 23:40
Stan.
Huh? whats that ? i dont know whats fitted
Posted 8th Feb 2010 at 03:01
any more idea's for me guys i really need to get this sorted asap 2 sell it
Posted 24th Mar 2010 at 22:47
BUMP
Posted 24th Mar 2010 at 22:48
Was the head gasket knackered????Huh?
As above,liner seals probably,but could also be oil modine(heat exchanger)
Is the coolant system getting pressurised??????
Posted 25th Mar 2010 at 02:10
miles
if your car is pre 92 then you won;t have a heat exchager fitted, if after this it's hit and miss.
But could be liner seals, The protrusion really only applies to new seals and not old ones but the liners should seat just above the deck.
I've known the water and oil pipes to be mixed up before as well
www.pugracing.com
Posted 25th Mar 2010 at 02:36
ya its a 1990 i gave it to a mechanic n it came back worse than it went in he says its not his fault and he's not at fault ,is it a big job to do them seals ????? how much would it cost me to get them
Posted 27th Mar 2010 at 08:42
antcla.85
IMO, liner seals is a fair job, head off, sump off, pistons out liners out, cleaning the block and liner very well and re-sealing o-rings. Prob even more, just buy another engine for a few hundred off ebay.
Life is short, make it interesting
Buy a Peugeot!
Posted 28th Mar 2010 at 02:36
