Author Subject: KNOCKING NOISE ARRR!!
dunebugs
Hi all i am new to all this forum stuff but i can only try just got my first 6 in need of a bit of tlc but its got this very loud and annying knock when pulling away with any sort of effort i first thought was driveshaft but after replacing both and the noise not changing i was looking at the bottom mount but cant see much movment in it when using a large lever bar any ideas will help
cheers
Posted 3rd Feb 2010 at 21:00
sport1901966
You may well have checked when changing the driveshafts but I had a similar noise a result of loose subframe bolts. Although it was more like on 'clunk' when braking or pulling away.
Edit - Could also be the top mount, water tends to trap in the well and the chassis corrodes. Support the engine with a jack and take of the mount, should only take 20mins or so.
Posted 3rd Feb 2010 at 21:10
dunebugs
no i didnt check the subframe but will do it now the noise souunds like the engine is pressed against the chassis when pulling off but cant see any clean spots where it would be hitting is it worth just getting a bottom mount to try ?
cheers
Posted 3rd Feb 2010 at 21:12
spike_uk06
Engine mount is probably your culprit.
Team China
Team Pirelli
Team Cracked Bumper
92k
20th Nov 1999 she was born
Posted 3rd Feb 2010 at 21:22
dunebugs
cheers ill be doing some mounts tonight i think
Posted 3rd Feb 2010 at 21:28
sport1901966
If the bottom mount was the problem I would imagine it would be more likely the exhuast contacting the chassis (this also could be caused by a poorly mounted exhaust - I had this problem tooRoll eyes).
Posted 3rd Feb 2010 at 22:15
dunebugs
done bottom mount and its now nice to drive without it sounding like its gonna fall to bits cheers Big grin
Posted 8th Feb 2010 at 21:25
dragoon
mmm I've got the same problem... decat hitting the subframe... although everything is mounted correctly, and all engine mounts have been replaced, can't think of anything else Sad
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 9th Feb 2010 at 00:47
steve_l_gti6
i think that means your cars a write off mate.
A sign of being crashed quite hard and then being repaired when it shouldn't have Wink
Posted 12th Feb 2010 at 07:55
steve_l_gti6
Dont want to alarm you tho LOL
Posted 12th Feb 2010 at 07:56
scott.n
cheers
This is the exact problem im getting but only when applying some heavy throttle in 1stt 2nd 3rd .. I think its my top mount thats knackered though ... Got a full set of Baker mounts coming so hopefully fix my problem aswell ! Big grin
Posted 24th Feb 2010 at 16:31
Cracked top engine mount cup, check under the big round engine mount, sounds like the usual problem.
Posted 24th Feb 2010 at 16:33
gilesy
dunebugs wrote:
KNOCKING NOISE ARRR
You quite possibly have a one legged pirate walking around your car LOL LOL
Have you checked for parrot feathers?Razz
Posted 24th Feb 2010 at 16:36
walker_texasranger
gilesy wrote:
dunebugs wrote:
KNOCKING NOISE ARRR
Laugh my ass off
I had the image of Peter Sellars, a fake wooden leg and a blow-up parrot Smile
Hilux InvincibleX daily
306 No.13 Doh
Posted 24th Feb 2010 at 16:46
scott.n
Will check that when doing the mounts , is it easily welded if cracked ?
Posted 24th Feb 2010 at 17:22
Very easy if you can weld ok, needs to be thick plate though, 3mm minimum or else it will just go again in no time, also you really want to chock the mount up with packers of some kind or else you will be doing it again at some point. Once done though it will drive smoother anyway as the engine doesnt rock back and forth anywhere near as much, why they didnt make the buffers fit better in the first place I'll never understand.
Posted 25th Feb 2010 at 01:36
