Thomas - Black 6 rollin' on black 15's...197bhp - 155.8bhp/135.4ft-lb atw
| Author | Subject: Bottom end rebuild... |
availablebmx
Regular Location: Leigh-on-Sea, Essex Registered: 24 Oct 2007 Posts: 355 Status: Offline |
Just got a rough price from a reputable local garage of around ________________________________________ Thomas - Black 6 rollin' on black 15's...197bhp - 155.8bhp/135.4ft-lb atw |
you haven't said what's included in that price, Autodata states its 28 hours for a complete engine, 25 hours for a bottom end alone or 8 for a cylinder head remove inspect and refit.to do it properly you'd have to take the head off as well to change the piston rings, in which case you might as well get the head checked and fit new valve stem seals and a headgasket at least. If the head isn't coming off though they're just doing the main and big end bearings, that's about ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
Is that with you taking them the bottom end or are they stripping it out? its a huge amount of work if they are removing and rebuilding. Whats wrong with the engine? |
availablebmx
Well I'm not totally sure what work is going to be envolved as they are going to inspect the damage... But as a rough idea to rebuild the bottom end he said 6-700!I done a bearing at my last track day whilst the engine was running with 140degree oil temps... Oil cooler on the list me thinks ![]() ________________________________________ Thomas - Black 6 rollin' on black 15's...197bhp - 155.8bhp/135.4ft-lb atw |
i think that sounds well cheap, surely they cant be fully rebuilding it new for that?________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
pdd144c
Senior User Location: Southampton Registered: 09 Dec 2005 Posts: 550 Status: Offline |
availablebmx wrote: I done a bearing at my last track day whilst the engine was running with 140degree oil temps... Oil cooler on the list me thinks ![]() And you kept driving it?! That price seems very cheap. ________________________________________ FOR SALE205 Turbo Technics complete and 306 Rallye Race Build breaking. |
miles
As said depends on what they will do, A crank out, Grind (If possible with a spun shell), Bearings and Seals etc is a good ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
r*byb
Regular Location: Tamworth Registered: 15 Sep 2007 Posts: 421 Status: Offline |
Off topic are there any updated shells? Are these acl bearings same price? ________________________________________ Team Low Compression |
rich_w
Seasoned Pro Location: Havant, Hampshire Registered: 29 Jul 2004 Posts: 5,412 Status: Offline |
The ACL bearings are the ones I supply which are also available through Miles @ Pug Racing.They are a tri-metal construction, mainly made up of copper with a lead overlay, and are much more durable than the OEM alu-tin type bearings. They also have a fractionally bigger running clearance, for better oil flow, to improve lubrication and heat dissipation. ![]() ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
rich_w
As for the rebuild price, I would guess that is the price for replacing the crank / shells in situ rather than taking the engine out.There's nothing wrong with doing it that way, unless the failure is severe, and the bearing has spun around within the cap. If this is the case, you will have to take the engine out, get the head off, and replace suspect rod, as the big-end will be stretched and out of round. Your bill will be much bigger then. Rich. ________________________________________ Contact Details:rich@lynxpowerengineering.co.uk 07732 822546 |
how much is a set of std size big ends?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
rich_w
availablebmx
I might have to get them of you then rich, along with one of your lightened and balanced flywheels...I'll pm you soon ![]() ________________________________________ Thomas - Black 6 rollin' on black 15's...197bhp - 155.8bhp/135.4ft-lb atw |
