Author Subject: vacuum pump
lilnickgti6
Hey everybody. i need to replace my vacuum pump, loud knocking coming from it! traced the knocking to the vacuum pump so going to try changing that and an oil change.
ive found a clean looking one 2nd hand for
Posted 2nd Feb 2010 at 23:25
yes, its VERY easy, just two or three bolts secuting it to the head and a single vacuum pipe off the top of it.
lube the o-ring with a little engine oil before you fit the replacement, shouldn't take you any more than 5 minutes.
Posted 2nd Feb 2010 at 23:35
lilnickgti6
thanks welshpug, ill have a crack myself when it arrives. how hard is it to line it up with the cam shaft? wat oil would you use also welshpug?
Posted 2nd Feb 2010 at 23:47
dr-evil
Your best opening up your replacement and check it for shrapnel - if your knocking noise is a loud tapping/rattling noise then it will be that the flimsy little piece of tin that sits on the end of the drive gear needs its ears bending back a touch - did this on mine and almost completley shut it up Big grin
Cad Monkey will work for chocolate biscuits....I'm not kidding
Posted 4th Feb 2010 at 03:08
lilnickgti6
damn, already ordered a new one. or did you mean check the repacement when it arrives?
Posted 4th Feb 2010 at 22:06
lilnickgti6
fitted new one today,myself. and it fixed the problem, no horroble knocking now
Posted 5th Feb 2010 at 23:43
justinaccurate
Vac pump was the first thing I did on the 6, got me into repairing stuff myself. you'll soon be replacing radiators mate Wink
Posted 6th Feb 2010 at 04:42
