Author Subject: cambelt tensioner
captian pugwash
hi guys, wanting some advice here,
my cambelt is due a change (2.0 16v) and im psyching myself up for it, though i read in the Heinz manual there is a choice of a manual or dynamic tensioner , going off what the book said i should have the dynamic tensioner though my experience of these books tells me not to trust anything, I really don't fancy prodding / twisting the belt to check tension but would rather i had / could fit a dynamic tensioner, however my parts supplier says they only list the manual tensioner for my car,
so my question is......
can i get / fit a dynamic tensioner if i haven't one already?
if so what else may need to be changes as a result ?
cheers for any help Cool
Posted 1st Feb 2010 at 02:02
fletch
Track Head
Theyre both manually tensioned but the "dynamic" tensioner as you call in has an indicator to help set the correct tension. You need to ask for the 137 tooth setup if you want that tensioner, someone will be along with the part number soon im sure.
Posted 1st Feb 2010 at 02:28
captian pugwash
cheers,
anyone with a part number then ?
Posted 1st Feb 2010 at 12:08
dynamic tensioner = plastic 137 tooth setup = pretty crap.
you need to take the timing belt cover off and check which you have, though IMO I would fit the 136 kit regardless, you would need to buy a stud for the tensioner to bolt to if it was the 137 kit on there and you want to use the 136 one, it's about
Posted 1st Feb 2010 at 15:23
captian pugwash
cheers for the info welshpug, i apreciate that, so i expect to find a manual tensioner which is what my parts geezer says is so, just got confused about haynes manual saying there could be both, but i suppose the other 2.0 16v engine that could have the dynamic tensioner is you guys?
Posted 2nd Feb 2010 at 01:12
the 1.8 used them briefly, hence the mention of them in the manual, the gti6 wasn't covered in the Haynes unfortunately.
Posted 2nd Feb 2010 at 01:37
is there a mark on teh tensioner on the 137 tooth kit, to say when its at the righ tension??
andy
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd Feb 2010 at 04:24
yup, you line up the pointer with the notch, RTFM as they say LOL
Posted 3rd Feb 2010 at 04:51
lol, i never notcied a pointer and notch, its so bloody tight down there, i just checked the tension by hand, i think its time i recheked it now.
Posted 3rd Feb 2010 at 14:28
