Author Subject: Crank Shaft Oil Leak
cabbymeg
Hi All,
I've got an oil leak on my car, it's coming from the flywhhel end of the crank.
The oil seal was replaced just before Christmas. Yesterday when I replaced the clutch I noticed a little oil coming from one of the flywheel bolt holes. I wasn't worried at the time as I was replacing the flywheel bolts and presumesd this would fix it.
I was wrong.
It seems worse than ever. The leak didn't look to be coming from the oil seal itself and it now has new bolts. So what the hell is going on? I'm getting a patch of oil on the drive evertime I park up about 2 - 3 cm in diameter.
I've got no issues with stripping it down again (got it down to about 5 hours now to strip/rebulid!!) but I don't know what to do with it when I do!
Any ideas?
Posted 1st Feb 2010 at 01:33
darkgti6
Isnt there a notorious leak from a hockey stick shaped metal component behind that oil seal thats to blame?Unsure
Mine has been leaking from there ever since Ive had this car albeit not bad - and I also thought the leak was coming from the flywheel oil seal which is why I had it changed when I had the clutch done but to no avail.
Team Peugeot Sport 308 Gti�
Posted 1st Feb 2010 at 01:55
puglover Banned!
its norrmal for oil to come out the lowest bolt hole but i guess you need to use a thread locker and am presuming this was done.
Its either the crank seals f*cked but not likely.
Or Probably the shitty pug end cap seals. IN which case total c*nt to do.
Posted 1st Feb 2010 at 02:56
cabbymeg
Yeah thread lock was used adn the seal is fine.
What's the end cap seals? I'm guessing its a 'box and sump off job?
Posted 1st Feb 2010 at 04:34
puglover Banned!
Yes
sump and box off and then undo the end piece of engine block that secures end of crank in place. use new seals and autojoint.
Posted 1st Feb 2010 at 04:57
cabbymeg
Any ideas on part numbers? I can't see the parts you are refering to on servicebox, just the crank oil seal
Posted 1st Feb 2010 at 17:45
Haynes manual covers the replacement of the seals Smile
0127 40 is the part, listed with the block not the crank.
Posted 1st Feb 2010 at 17:55
I've got 8 in my garage in a bag if you need a coupleBig grin
Helpfull Pug dealer ordered me 2,they came in a bag of 10 and he would not split them as not a stock itemRoll eyes
Posted 4th Feb 2010 at 03:00
this is it:
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 4th Feb 2010 at 03:03
