Author Subject: Anyone had this before
cact1972
Help please guys!!!
Last year i changed all my pads and discs a few corroded pipes on the rear and a new compensator since then (dont think it was doing it before??) My pedal is rock hard when not running then drops slightly on start up and if i keep the pressure on the pedal still keeps going down?? I have put a new vaccum pump on changed the master cylinder and tried another abs unit!
Anyone got any ideas ?
Posted 31st Jan 2010 at 20:51
cact1972
Bump
Anyone???? please
Posted 2nd Feb 2010 at 21:06
jonnyboy17
re-bleed the system?
Team Dirty Black... Formerly Known as Astor
sharland wrote:
When women don't behave like they do on brazzers.com in real life it disappoints me.
rikky wrote:
the day i own a credit card is the day i saw my helmet off and fire it from a potato cannon
Posted 2nd Feb 2010 at 21:10
cact1972
System has been pressure bled 3 times by my local garage even he is scratchin his head with it!!
Posted 2nd Feb 2010 at 21:20
birk
The pedal will get hard when the car isnt running, then when you start it, the pedal will sink, thats how the system works.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 2nd Feb 2010 at 21:33
cact1972
Yeah i understand that is how the system works but it should only move an inch or so then be solid! But mine moves the inch or so and if i keep pressure on it carrys on moving to the floor but with a bit of resistance?
Posted 2nd Feb 2010 at 21:39
So does mine, but it doesnt loose fluid and the brakes work fine when driving, is there actually any issue while on the road?
Posted 2nd Feb 2010 at 21:45
fletch
Track Head
Might be a faulty caliper seal
cact1972
No fluid loss so same as your saying! it stops on a pin but sometimes the pedal goes quite a way down on braking and other times not so far (not consistant level)
Just that sometimes it feels a bit un nerving when I need to stop quickly and the pedal nearly hits the floor!Shock
Posted 2nd Feb 2010 at 21:58
fletch
Track Head
Must be some air getting in there. Was the replacement MC new or 2nd hand?
Posted 2nd Feb 2010 at 22:04
birk
Servo
07889376885
Dan
cact1972
When it has been bled no air is in the system??? Mc is new!
Posted 2nd Feb 2010 at 22:10
cact1972
birk wrote:
Servo
Have thought of that myself but dont know how to test it??? And it is the worst case scenario and i believe its a b*tch of a job!! Mind you My heater matrix has just spat its dummy so its coming out v soon.
Posted 2nd Feb 2010 at 22:09
birk
I had the same symptons, but mine got to the point where the servo was that shagged, it made the brakes come on, i changed everything on the brake system, inlcuding the brakes, thinking it was them that where seized or leaking.
My heatermatrix was also on its last legs, so when i had the dash out, i replaced the servo and it cured the problem.
07889376885
Dan
Posted 2nd Feb 2010 at 22:27
cact1972
Posted 2nd Feb 2010 at 22:32
birk
I got away with just the top engine mount, but if i was to do it again, then i would do the gearbox side aswell, just for the extra bit of room.
07889376885
Dan
Posted 2nd Feb 2010 at 23:13
cact1972
Spot on thanks fella! Both of them need changing too the new ones are in my garage waiting to be fit. Got a bit of work on, me thinks!! Huh? anyhow gonna have to leave it for a couple of weeks due to work commitments!Angry
Posted 2nd Feb 2010 at 23:18
cact1972
Reet, have now changed the servo ( spent a fookin packet on this prob now,m/c,abs pump,compensator and vac pump)And it is still the same! Starting to think that it is a dodgy master cylinder. Is there any way of testing them?
Posted 15th Mar 2010 at 03:54
sounds like the M/C is letting fluid past one of the seals if the pedal sinks to the floor and there's no fluid loss, only thing left it can be really.
Posted 15th Mar 2010 at 04:09
cact1972
Yeah my thoughts too. Just hope the parts supplier will exchange it! I have been chasing this for months now.
Posted 15th Mar 2010 at 04:23
motorman
It does not sound like the MC seals if it doesnt sink when the car is not running?
Posted 11th Apr 2010 at 02:55
oldbrownshoe
read the break section , i'm sure you'll find the answer there.
http://www.tegger.com/hondafaq/faq.html#brakes.
also try first to bench bleed the MC
French military victories?
Did you mean French military defeats?
Posted 11th Apr 2010 at 17:20
motorman
Just read that, so it could be the master cylinder?
I too have the same problem & I will be fitting a new MC shortly so It will be interesting to see if it helps.
Posted 13th Apr 2010 at 00:52
