| Author | Subject: brake bleeding |
chris 6
Junior User Location: leicester Registered: 11 Nov 2008 Posts: 82 Status: Offline |
i cant get the air out of my system ive tried the 2 man way and those eezi bleed kits and i still cant get a solid pedel without pumping it a few times. Is there any type of sequence or any tips anyone can give me to bleed the system fully. |
check that the load compensator (if fitted) is not seized.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
chris 6
sorry mate not sure what that is?? |
chris with a pug
Seasoned Pro Location: Southampton Registered: 16 Feb 2003 Posts: 5,366 Status: Offline |
attatched to the rear beam there is a compensator. that is what he means. |
chris 6
oh ok mate i know wat that is now. |
tvrfan007
Seasoned Pro Location: In the garage Registered: 29 May 2005 Posts: 3,488 Status: Offline |
I would suggest finding a loose surface, like gravel, stamp on your brakes to make the abs cycle. Drive for circa 50 miles with lots of braking - rebleed and you should find air at a nipple. ABS distribution blocks tend to store air, especially when you've had lines off as well as calipers.________________________________________ I'm Si btw![]() Night Blue VW Golf GTD Bianca LBSC Rallye - Track/Road Slag Project Thread Sparkling Silver Mini Cooper D - Super Dooper - (The other half's wheels) |
chris 6
ok ill try that |
