I also had this with a 309 i had, one of the liners had a small crack in it, symptoms just like head gasket failure
Team Supercharged Gti-6™
displaying posts 26 to 32 of 32
Pages (2): 1 [2]
| Author | Subject: Low compression, rad cap leak, water temp Q's |
davedgti6
Seasoned Pro Location: whiston, prescot Registered: 28 May 2006 Posts: 1,651 Status: Offline |
pete_rallye wrote: Exactly the same issue as I had when I had a cracked block. Thought it was the HG so changed that but was still the same with the new one on. Bore had a tiny crack in it that was pressurizing the water system, causing water to overflow out the rad cap. If you run it like that it can cause the oil and water to mix knackering the bottom end pretty quick. I also had this with a 309 i had, one of the liners had a small crack in it, symptoms just like head gasket failure ________________________________________ Team Supercharged Gti-6™![]() |
r*byb
Regular Location: Tamworth Registered: 15 Sep 2007 Posts: 421 Status: Offline |
I'm so annoyed! Car is now going to cost me the vest part of 1k to be fixed after the 600 pounds last week for the hg to be done which didn't solve the compression/missing problem the hg was re- done for in the first place, used the car still and after sighting laps so not even driving hard, my bottom end is knocking which is apprently a result of the compression the head now has, I really can't get my head round this!! It's going to be an engine that's cost me 1.5k in 2 weeks. I really don't know what to do or think, so gutted!!________________________________________ Team Low Compression |
most likely cause of the bottom end knocking was the oil and water mixing when the head gasket went________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
r*byb
Oil water hadn't mixed at all, it wasn't that part of the gasket that's gone ![]() ________________________________________ Team Low Compression |
mechanical_repairs
A little insight- Car came to the garage for some repairs, whilst having the car in it didnt run to well, carried out a compression test and one of the cylinders was down, other than this the car ran ok ish, no oil in water or vice versa. We removed the cyl head to find it had recently been off, three rounded off head bolts etc, the head had been skimmed but not enough, you could see where it had removed the surface and area's where it hadnt, most of the exhaust valves were leaking and needed the valve seats re cutting and a decoke, all this was carried out and put back togther, all the compression's where better and the cylinder with the lowest had increased by 30psi but still not up to scratch. Advises Rob not to do a track day as at the minute the engine was still repairable, the car left and obvoisely now we have the issue where it has ran the bearing shells out. Still repairable but alot more workj involved as the crank will need to be removed to have it polished or re ground. Bugger. Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
r*byb
Cheers for making it clearer than I can Carl.Would the shell of not gone anyway regardless ________________________________________ Team Low Compression |
mechanical_repairs
r*byb wrote: Cheers for making it clearer than I can Carl. Would the shell of not gone anyway regardless Its a tricky one, its one of those things you just never know, they are not the sort of things you can see unless you strip the engine down so they are never checked, common things that wear them out are poor lubrication, in frequent oil changes giving the engines grief when cold etc. As the cars done 100,000 if i remember right, you will never know the cause. A track focused car will always wear thing out quicker than a road car not just the engine, its given more abuse when its used. Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
Pages (2): 1 [2]
