Author Subject: Cannot select 5th or reverse
mattym129
If I try and get the 6 into 5th, it does not move up and right. If I try and get reverse, even with the pull-up thing pulled up, the reversing lights do not come on.
She's still a non-runner so I thought it might be just the gearbox in an odd position, but it's been towed twice and neither time after stopping could I select 5th or reverse.
Am I looking at a new box? How hard would this be to repair with my very experienced dad?
Cheers!
Posted 28th Jan 2010 at 20:25
jonnie205
more likey to be some sort of linkage problem
Posted 28th Jan 2010 at 21:53
mattym129
I'm still having a problem with 5th and reverse!
I've now put a new box and engine in, the linkages are definately on right but I still cannot get these gears with the stick!
If I take off the biggest linkage I can select them on the gearbox, so I think it's the stick. Anyone know what it could be?
I will investigate the ball joint in the centre console on friday.
Cheers!
Posted 31st Mar 2010 at 16:38
gti6loon
Id better just state the obvious..just in case.
Is the reverse cable definately connected to the box?
If i remember correctly if it not connected you wont be able to get 5th and 6th as well.
Steve
Steve
Planning a ring trip? Why not stay at Hotel Burgstube
Posted 31st Mar 2010 at 18:56
birk
Did you check the clutch ? when my clutch had bust i couldnt select reverse gear, and the 2nd time it could hardly change gear, this time around its the same aswell.
Try it with the engine off and see if it goes in.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 31st Mar 2010 at 19:28
mattym129
I take it the reverse cable is the silver one - this was connected no problem.
There was a cable included with the car, I will check it to make sure.
If I take the gear stick gator off, will I be able to check the reverse cable?
Cheers, Matty.
Posted 31st Mar 2010 at 21:56
mattym129
Just had a look, I can get all gears!
I must of had the cable off last time, but it's definately working fine now!
Thanks for any help, Matty.
Posted 31st Mar 2010 at 22:43
mechanical_repairs
Bet you thought i had sold you a duff?
Glad you sorted it.
Carl
Posted 31st Mar 2010 at 22:58
mattym129
Nah, I knew it wasn't a duff off you!
It was doing it before so it must of been the reverse cable. Why do Peugeot have to do strange and weird things?
I'm buying a 1.0l Micra.
Posted 31st Mar 2010 at 23:01
