Author Subject: Fitting airbox
fozzy_255
Well im trying to replace the K&N filter with the original box and pipework.
Problem im having is how to get it into position without taking loads apart.
So far i have tried by removing the wheel arch and going from under the car but the 'splash guard' attached to subframne is in the way.
I didnt really want to remove the top rad hose as means bleeding the system.
Is there and easy way to do this.
Thanks John
Posted 27th Jan 2010 at 00:50
i refitted a std airbox at weekend
i removed the wheel, pulled the arch liner back to the disc and undid the map sensor but that was it. bit fiddly but nothing hard..
i refitted the bottom box and did the screws up etc, then the top ducting section by feeding it into the gap and rotating it into place, then tightening it up, then doing the TB end
Posted 27th Jan 2010 at 01:00
fozzy_255
May be sounding a bit dim, But whats the map sensor.
It senses whether you have a map in the car or sat nav. Set up is removable while car complete so should be fittable other than arch liner and jacked up so you can access from underneath and side.
Posted 27th Jan 2010 at 07:12
LOL
you will see it at the end of the manifold near the throttle body. it will immediately be in the way when trying to do anything
it's not a hard job by any means, just a bit fiddly
Posted 27th Jan 2010 at 17:41
funscott
to remove mine i took thee passenger wheel off then undone splash panel attched to the wing liner and i could get it out without issue. i split the resinator from the filter first.
Join Quidco the top cash back site and earn £1.25 from my referral link (once you earn £5) http://www.quidco.com/user/571859/1838
Posted 27th Jan 2010 at 18:08
fozzy_255
Thanks Have fitted the box. Very fidly.
But i have this pipe and no idea where its from?
Posted 27th Jan 2010 at 23:11
This pipe goes backwards to under the battery.
Posted 28th Jan 2010 at 00:34
fozzy_255
What is it purpose?
Posted 28th Jan 2010 at 01:07
fozzy_255 wrote:
What is it purpose?
I think it's there to cool the ECU.
Posted 28th Jan 2010 at 02:03
fozzy_255
Interesting, never heard of an ecu cooler, i will try fit it back on then. I am tryin to put the car back as standard as i can.
Posted 28th Jan 2010 at 02:23
bonesy_1
ha ha i think hes takin the mick?? battery spill pipe to remove any acid, or so i was told.
Posted 28th Jan 2010 at 03:02
fozzy_255
Oh Blush
I see your from dover, you own a 6?
Posted 28th Jan 2010 at 03:10
bonesy_1
yes mate, a blaze p2 just finished rebuilding it after an eye watering tensioner fail. just put my rocker covers and inlet mani in for powder coating today, cant wait to get thrm back. didnt realise there where any 6's local. know of any more? andy
Posted 28th Jan 2010 at 03:16
lwgti-6
Laugh....my...arse...off!...LOL
I actually LOL'd!
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 28th Jan 2010 at 03:18
fozzy_255
I'm a Rallye owner (stick my nose up) just kididng i bought it from a member a couple of months ago. Don't know of any other members close by. But im sure there are some.
Where did you get your parts powder coated as i was thinking of getting some cyclones done.
Just for the record as people seem to be enjoying makign lil jokes, im not as dim as i sound people. Im used to the 1.4 engine where there is plenty of room around the engine. So much infact that your could most probably sit in the engine bay and fix it Smile
Posted 28th Jan 2010 at 03:34
f*ck me how much acid do you think they leak?! it's probably for fume ventilation from charge gas Erm?
Posted 28th Jan 2010 at 04:09
bonesy_1
hey you oviosly never seen one of my cars Wink having them done at euromark powder coatings over at margate there are prob closer but i deal with them for work, plus they have a sand blasters next door so its easy.
Posted 29th Jan 2010 at 01:27
