Author Subject: alternative to coilovers - springs and dampers
gti-dan
what are the best combination of dampers and springs for trackday use? what sort of lowering am i looking for from the springs?
this coupled with lowering the rear beam - will this be a good enough set up?
Posted 25th Jan 2010 at 00:46
SteviePut
Billie B8's seem to be the shocks of choice and what I'm going for when I can be arsed to order them.Couple them with Eibach springs (which lower ~30mm) and you'll be fine.
Posted 25th Jan 2010 at 01:31
lotek
B8's are a good move. Yes
Posted 25th Jan 2010 at 04:30
skinnyman76
i just got a spax nitrogen 40mm kit for
pug power !!!
i got the need for a 6 speed!!!
Posted 25th Jan 2010 at 04:57
cjslator
these B8's, are they the ones with the big pistons? or just normal OE type jobbies?
Posted 25th Jan 2010 at 06:25
Rich E Forum Admin
OE type but firmer and with shorter rods on the fronts.
They're a good compromise for a road / track car but TBH they're a little too soft for focused track car.
Posted 25th Jan 2010 at 06:32
fletch
Track Head
I would say KW V2 coilovers with a stiffer spring would be a great front setup for track.
Also thicker rear arb and Koni/KW rear dampers without breaking the bank.
Posted 25th Jan 2010 at 14:42
fletch
Track Head
f*cks sake just reread the title 'alternative to coilovers', sorry Doh
Posted 25th Jan 2010 at 14:43
I have Avo dampers with Eibach springs on a 30mm drop, and seems like a good fast road/trackday setup.
There is adjustable damping control so you can set it differently from track and road.
Posted 25th Jan 2010 at 15:39
soton_s16
I've got this on my 306, and works extremely well Cool
Rear beam rebuilt
BTCC Rear ARB
Solid Rear Mounts
Bilstein 306 Front Dampers
Bilstein 205 Group N Rear Dampers
Eibach -30mm springs
Front strut brace
Roller Bearing Wishbone Bushes
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 26th Jan 2010 at 00:10
The eibach / Bilstein B8 combo is a good one. Couple that with new beam bushes, new P bushes and a SPOOX/Ash hybrid ARB and it'll work very well. Might be a little soft for a track only car - you really want to be spending a bit/lot more and getting a good coilover setup (KW/AST).
Also invest in some lightweight 15" x 7" wheels with the correct offset
Posted 26th Jan 2010 at 20:46
