Author Subject: Spongy pedal poor brakes but Uprated..
r*byb
Hey guys, took the rallye for a good run today.
It has standard fluid and lines as i haven't fitted my braided ones yet. It has Brembo plain discs and Mintex1155s done about 50 miles with them on now.
Basically the pedal feels terrible, very spongy and no real bite at all, and they also seem to of over heated big time on a brisk drive, (by no means slamming on) cause they smelt like cooked brakes and litrally didn't work at all!!
Any suggestions on why ? they seem to bite quite well when cold but as soon as there is any heat they die off, even though there super high temp pads..
Cheers Rob
Team Low Compression
Posted 24th Jan 2010 at 20:55
if they have only done 50 miles then there is your answer, give it chance to bed in.
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 24th Jan 2010 at 21:15
mr swampy s16
**BAD SELLER**
Get them bedded in correctly.
Did you clean the protective coating off the disks?
Posted 24th Jan 2010 at 21:30
r*byb
Noo, i didn't know they had a protective coating ?
Posted 24th Jan 2010 at 21:37
tvrfan007
Discs are usually treated with an oily anti-corrosion compound which you need to wipe off with white spirit and a rag before you put them on the car.
Then the pads need bedding in. When was your fluid last changed?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 24th Jan 2010 at 21:40
mr swampy s16
**BAD SELLER**
Yeah when new all disks have an anti corrosive coating on them.
I always clean both faces of the disk up with brake cleaner to remove it.
r*byb
Never new that!, is it worth doing now as ive done 50 miles..
Fluid hasn't been changed for about 3 years 25,000 miles probably..
Posted 24th Jan 2010 at 21:41
tvrfan007
That's not going to help then since fluid is usually recommended every 2 years...
Not worth it now if you've driven the car. Not every disc is treated as some just come in wax paper.
I'm Si btw Tee hee
Posted 24th Jan 2010 at 21:43
r*byb
They came in browny coloured paper is that the stuff ?
Posted 24th Jan 2010 at 21:46
robthe6
yeah oil'd paper. i would spray some cleaner on anyways just to see if it helps. as once your pads have ran on the oil of the disks iv heard there f*cked for life.
1997 ph1 bianca GTI6 - The looker
1996 ph1 Sigma GTI6 - Dead Sad
1999 Red Rallye - The Daily
2005 Nissan Navara D40 - Family car
1968 Mustang Coupe - The dirty little secret
Put ya foot down, put ya foot down we'll loose em easy!
Posted 25th Jan 2010 at 01:38
