displaying posts 1 to 1 of 1
Author Subject: Strange electrical problems, possibly a bad earth???
horn
My phase 2 has been acting strange for some time now, firstly the off side indicators would stick on and randomly switch on by them selvs, I have changed the alarm ecu and the indicator relay and it still happens on the odd occasion, but when it does happen the indicators are slightly dimmer than usual. Also when you press the break pedal, the break wear indicator light would come on, so I checked all the breaks out and they were fine.
I then thought I would try an ECU re set this morning, following this the indicator ligts are no longer dim and I havent had them stick on yet, but now when pressing the break pedal the rear fog light comes on and if you indicate right the rear for light flashes with the indicator which has made me think I have a bad earth some where?
I have checked the earth points under the rear seat, and the main one from the battery to the gear box and they are both fine, how ever there was some damage to the earths near the accelerator pedal, caused by the cable. I have repaired these and all of these things are still happening.
I would be very grateful of any help or advice of what i should try next!
just go faster
Posted 24th Jan 2010 at 20:44
