Author Subject: Engine stalls
iplay
Intermittent problem ... When driving along sometimes the car just dies. if i keep the accelerator pedal in exactly the same place without lifting off the car then picks up after a few seconds.
I can see this being either fuel pump, PAS sensor, injectors, fuel filter (although surely the fault would occur more often), engine temp sensor, contaminated fuel?
Any help most welcome
Posted 22nd Jan 2010 at 19:31
cabbymeg
Maybe an earth problem? Do the dials do anything funny on the dash when it happens?
Posted 22nd Jan 2010 at 19:41
iplay
dials do not move ...
where is the earth for the fuel pump?
Posted 22nd Jan 2010 at 20:30
gti6dave
I had the same problem, turned out to be the lambda sensor
Team Supercharged
Email:
davebrowse@hotmail.com
Posted 24th Jan 2010 at 00:19
Try un-plugging the PAS sensor and go for a drive, and see what happens mate...
If it's still the same, then plug it back in and do the same with the lambda. Yes
Stan.
Posted 24th Jan 2010 at 17:56
matt_gti
How could a faulty PAS sensor cause the engine to cut out?
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
E39 535i - Daily driver
*Newest edition* E60 M5 5l v10 - The weekend car Smile
Posted 26th Jan 2010 at 02:20
carlosw828
Cus the engine ecu has to see what pressure the pas fluid is under in order to match the revs so it doesnt cut out under heavy steering.... if the ecus seeing an incorrect/faulty reading then it cant adapt the revs to match hence why it might cut out.... however i cant see it being bad enough to stall whilst driving at mid range revs??
Posted 28th Jan 2010 at 20:17
