Author Subject: pic request- engine loom
turbowagon
hass any 1 got a pic of the engine loom either gti-6 or xsara vts on the engine with out the inlet on? reason i ask is i have no plug to go on the sensor by the oil filter (see pic) just wondered if it was different on the xsara loom compared to the gti
http://www.flickr.com/photos/32464394@N07/4294696211/
i have plug for sensor behind the starter but not the 1 by the filter
slowest project car ever.com
Posted 22nd Jan 2010 at 18:19
birk
This any help fella, think thats the best pic ive got.
Found this one aswell
Thats the oil temp/oil level sensor iirc.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 22nd Jan 2010 at 18:33
turbowagon
kant quite see im trying to work out if both the sensor behind the starter and the one by the filter r both connected?dont spose uv seen?
Posted 22nd Jan 2010 at 18:31
turbowagon
sorry but whats iirc? thick moment
Posted 22nd Jan 2010 at 18:32
pugpete
If I Recall/Remember correctly Smile
Ex Black phase 2 GTi6(now dead)
Ex Sigma phase 1 GTi6(sold on)
Now in a low,slow,dented and dirty 306 Estate and a Jacked up P38 RangeRover.
Posted 22nd Jan 2010 at 18:37
birk
If i remember correctly Smile
The plugs should all be colour coordinated with the relevent sensors.
You can see in my pics that ther is a green plug, this isnt the one that goes on that white sensor, it should be a white plug.
07889376885
Dan
on later cars that plug was not used as there isn't a gauge or warning light for it, even if the sensor is fitted, many engines even had two identical sensors fitted.
Posted 22nd Jan 2010 at 18:38
birk
07889376885
Dan
Posted 22nd Jan 2010 at 18:41
turbowagon
so which 1 is more important if i only have 1 plug? engine is a 99 xsara vts
Posted 22nd Jan 2010 at 18:42
You need to work out which plug is for your oil warning light on dash if you haven't got oil pressure gauge????
If you've got oil pressure gauge you need to fit the sensor from an earlier car to the blanked off hole in the Xsara blockSmile
Posted 25th Jan 2010 at 02:45
