Author Subject: Please help, hissing.
nxa
Hi guys, I started the s16 up the other day and noticed a strange 'hissing' sound coming from the right side of the engine. At first I thought the radiator cap was loose or a coolant hose had burst, but they are fine.
It's quite a strange sound as I cant hear it with the bonnet open. It is loudest with the bonnet closed and while putting your ear next to the right hand wiper arm. Also loudest when standing behind the wheel rather than infront of the car.
I initially thought it might have been coming from somewhere in the cambelt cover (cambelt 50,000km old) but the hissing sound doesn't change at all while reving the engine.
This one has got me stumpedSad
Does anyone have any ideas?
cheers
Posted 18th Jan 2010 at 15:04
allesclar
could be a leaky pipe somewhere, the engine cooler pipe perhaps?
Team allesclar ®
Posted 18th Jan 2010 at 15:07
nxa
Coolant pipes are fine mate, vaccume diaphrams are working too so doubt it's an air leak.
It's not the exhaust/manifold/gasket either.
It's got me a little worried since you can hear the hissing while driving with the window down at low rpm. Unsure
Posted 18th Jan 2010 at 15:17
xsi_lew
i think i have the same (for a while now so cant be too bad) i can hear it when i have the drivers door open and sat in the drivers seat, mines more of a sucking sound than i hissing but it sounds like its coming from the same place?
Posted 18th Jan 2010 at 15:39
spencer
Check it's not the following:
PH2 306 GTI 6 Big grin
Team Nile ™
Posted 18th Jan 2010 at 17:28
s16? is it coming from near the back of the cylinder head? i had a vacuum pipe spliut at the back there which hissed and cause problems. i also had various vacuum leaks around the ACAV system and i ended up binning it all for the gti6 setup
Posted 18th Jan 2010 at 17:34
dan_s16
As rikky said it's probably the vacuum pipe that comes along the back of the cylinder head to the charcoal canister in the wing, they have a habit of splitting (mine went just where the bracket bolts it to the cylinder head, got a new one only for it to do the same thing again 2 years later so I blocked it off completely now)
Posted 19th Jan 2010 at 01:06
nxa
Thanks for the help guys.
I had a little look at it today and I think your right in regards to the vaccume leak behind cylinder head.
dan_s16, is it the charcoal canister that often needs replacing, or just the tubes that attach to it?
Finally, what sort of problems can a leak like this cause? would it be ok to drive the car as is until the weekend?
cheers
Posted 19th Jan 2010 at 04:26
dan_s16
just the metal pipe that runs along the back of the engine, i'm guessing the vibration just makes it snap after a while.
It used to make mine idle higher (think it was 1100rpm) and it would be unresponsive, would also stall a lot too.
Posted 19th Jan 2010 at 04:45
