Author Subject: Ph1 and Ph2 Wiper relays in different places?
docwra
Ive got a Phase 2 GTI-6 and the wipers started behaving strangely the other day - to start with they wouldnt work on intermittent, then not on slow, and then yesterday they packed up totally - the wipers got stuck in the middle of the screen and wouldnt move on any speed.
Ive cleaned the plug on the motor and its made no difference and I can hear the switches in the indicator stalk so I doubt its that, which leads me to think its relays.
The beauty of having two cars that are the same is that you can try bits from one to find the problem on the other, but when I looked under the dash on my Phase 1 last night, there are holes for the purple relays, but no relays. Are they somewhere else on a Phase 1?? Ninja
EDIT: Also, are XSI relays the same?? I can get some off a mates breaker if so Smile
Lots of Nissans, two 306 GTI-6's. They are catching up! Big grin
Posted 14th Jan 2010 at 16:47
anderoo
Phase 1's use different relays. Yes
I got some replacements from a scrapyard. As well as being used for (auto?) wipers on later 306's you can find them inside the plastic triangle between the two fans on some (possibly aircon only?) 306's & 406's. Spotted one in the engine bay of a 405 too.
Pics of my 6
My 6 on Google Video thanks to coxy306Xsi
Posted 14th Jan 2010 at 16:56
docwra
So much for "the same car" Dry
Ill see what my mates XSI uses then - I want to be sure its the relays and not the motor (although I could probably nick that off him too)
Cheers mate Smile
Posted 14th Jan 2010 at 17:02
anderoo
You could try swapping the relays around. My wipers stopped parking and by switching them around they only worked on the fastest setting so I knew the relays were the problem.
The motor should be the same as the Ph1.
Pics of my 6
Posted 14th Jan 2010 at 17:51
