Author Subject: XSI convert gti6 manifold
mc leong
refer :http://www.306gti6.com/forum/showthread.php?id=64213&page=last
After i convert complete gti6 inlet to my XSI. found that the idler is so bad. RPM up and down.
Any one know what is going on ?
Thanks
Posted 11th Jan 2010 at 13:32
ashcole
i found on mine there was another air pipe on the throttle body thats goes near your brake servo into a plug disconnect and clean with wd40 or somethin it sorted mine mate!
ashcole
Posted 28th Jan 2010 at 04:36
mc leong
I Will try it on . thanks
Posted 28th Jan 2010 at 06:52
asim_pug306
Same happened with my XS mate. Turned out to be a faulty breather filter
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 28th Jan 2010 at 08:04
24seven
I seem to be the only person who's done this and not had any issues whatsoever! Everything I unplugged from one manifold I plugged into the other.
Posted 28th Jan 2010 at 17:15
vernam616
Does this make a noticeable difference to the XSi?
Audi S3 Black Edition
Posted 29th Jan 2010 at 00:42
dan_xsi
only sound wise i think. may feel a bit more powerful at the top of the rev range. but its hard to tell.
Posted 31st Jan 2010 at 00:23
24seven
on my XS is made a noticeable difference to the sound and it definitely felt less asthmatic up to the limiter. The '6 exhaust manifold made a bigger difference with a very noticeable increase in torque when pulling away.
Posted 31st Jan 2010 at 18:11
pugmister
Personally I have done it and to be honest i think it is a total waste of time, although i have not got round to fitting the Exhaust manifold in. I think my xsi pulled alot better with the original manifold
Posted 14th Mar 2010 at 05:44
asim_pug306
Looks about 1 million times better though
'01 Astor Grey GTi6
'99 Cherry Rallye
Posted 14th Mar 2010 at 10:57
c.a.r.
It does, returning mine to standard in the next few weeks.
The engine isn't happy with both the manifolds being upgraded, it's choked up and is slowly killing its' catalytic converter.
'99 1.8 XS - Sold
'00 GTi6 - Killed by armco
'01 Cabriolet 1.8 - Sold
'96 Eunos Roadster 1.8 Import
Posted 14th Mar 2010 at 16:32
probably because it needs a remap.
Posted 14th Mar 2010 at 16:38
c.a.r.
Exactly, but the crappy Sagem units give the diagnostics testers enough trouble as it is, and I don't believe there's an easy way to remap them. Because of the additional air I think the sensors are confused causing it to overfuel, resulting in blocked catalytic converters and eventually high engine temps, resulting in burnt piston rings which is what Asim had.
It'll cost around
'99 1.8 XS - Sold
Posted 14th Mar 2010 at 16:48
