Author Subject: cooling fans problem
j306gti
hi all i know there is a lot of posts on this but cant find the problem still.
i have only one fan on(the drivers side)all the time as soon as i turn the key and its on high speed.the only things i can think of is the brown coolant sensor as nothing happens when i unplug it or a faulty relay.
any help on this would be great.Sad
Posted 9th Jan 2010 at 22:23
toby
If the fan is staying on it could be a relay stuck on, try swapping the two green ones by the fans and see if the fault moves from one fan to the other. If this doesn't find the fault then unplug the fan control box above the alarm siren in the passenger inner wing, clean up the contacts in the plug and socket then spray them with WD40.
Previous Peugeot - 2000(w)GTI-6, Me old China, Supercharged with working aircon!
Posted 9th Jan 2010 at 22:39
j306gti
ok thanks will give it a go tomorrow.cheersSmile
Posted 9th Jan 2010 at 22:50
