Author Subject: Name That Noise! please!
mjstones
i made the mistake of driving without the stereo on and have noticed some worrying sounds Sad . there is a slight knock when coming off power / braking sometimes on the drivers side front, also when driving there's a sort of quiet grindy noise that speeds up and slows down as the car does. Recently i have changed the : shocks, top mounts, and drop links. any suggestions cos it's driving me nuts. i need to put the stereo back in really, that'll solve it.
Never underestimate the power of De-Nile.
Friday afternoon car, built in France.... Ninja
306gti6.com Stickers available, pm me for details. or email MjStones83@hotmail.com
Sticker Thread with pics
Posted 6th Jan 2010 at 22:37
greenbelt
The knocking from the drivers side front is probably the top engine mount.
I had the quiet grinding noise on my old Diablo 6 and that was the drivers side front wheel bearing.
Hope this helps Smile
Standard Black 6
Black HBSC6 Smoke
Posted 6th Jan 2010 at 22:44
dragoon
seeing you already changed the topmounts and droplinks..
maybe the wishbones?
Team Wheelwhore
Team Limited Edition
Astor 306 Francorchamps RIP
Virtual Blue 208 GTi
quote:
I Love this place. So many illiterate deluded fool's acting 'ard . . . and so many literate intelligent people to rip them apart and knock them back down again . . . ahh Cool
Posted 6th Jan 2010 at 22:45
mjstones
i had the P-bushes done at carls just over a year ago so the wishbones should be fine.
the mount seems ok, there's no space for it to play about in but i might check into the mount / bearing problem. thanks! Thumbs up
Posted 6th Jan 2010 at 23:03
mjstones
would a bearing on the way out cause other problems that i would be able to notice? pulling, etc??
Posted 7th Jan 2010 at 00:06
tvrfan007
Check your strut top bolts are tight. I changed the strut on my drivers side just before xmas and about a week/1K later I heard a knocking noise that seeped to respond to power changes. Only thing in the whole assembly I could find loose was I could put a ¼ turn on a strut top bolt but the noise it was making you'd swear the whole lot was about to drop off.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 7th Jan 2010 at 14:14
mjstones
nuts are tight as. the noise gets worse in neutral and when i turn left. the car loves going right. i hate it so much i want to crash it into a wall. it's getting worse aswell it's like a constant wobbling knocking grindy noise from the front drivers side (the only way to describe it). it also goes away when i brake hard, but there is also a knock when i touch the brakes.
Posted 18th Jan 2010 at 22:34
hbinky
Knocking noise sounds like what I had when a split/ crack had developed in the chassis where the top engine mount bolts to. You'd have to take the top engine mount off to see what its like underneath. The grinding noise is also reminiscent of when my driveshaft started failing, could be the reason why its quieter turning one way rather than the other.
Posted 18th Jan 2010 at 22:58
lotek
top mount by the sound of it fella Yes
take the mount out and see what the chassis is like under it.
Posted 18th Jan 2010 at 23:00
mjstones
right, well f*ck goes my evening then. off to halfords to spend MORE money on tools. i really really hate my car. i hope someone steals it or burns it.
Posted 18th Jan 2010 at 23:20
smegal
Check that your P bush bolts are tight, this has caused a knock on acceleration for me before and is free to repair.
The quiet grindy noise could be a bearing, although I would try to rev the engine when it is stationary to see if it is only when moving.
Ex SC-6
Now in a Megane R26
Posted 19th Jan 2010 at 01:01
