Author Subject: Clicking Relays
shah_gti6
Over the past couple of days, when I'm driving along I've noticed that one of the relays (under the steering wheel) keeps on clicking away every so often, sometimes at an alarming rate.
I haven't seem to have lost any functions - all indicators, front wipers and other electrics function fine so I'm at a bit of a loss at what the problem is about from the annoying noise. And possibly a bigger failure whilst sitting in the middle of a snow storm! Unsure
Can anyone help in identifying:
1) Which one of the relays is at fault. Can I run a meter check on the relays to confirm if they work/don't work?
2) What each one of the relays do
I recall there used to be a picture someone had put on the site identifying each relay but I can't seem to find it Sad
Thanks for any help Thumbs up
Nile Blue 306 GTI-6 (2000V)
Posted 6th Jan 2010 at 18:26
most likely to be the indicator relay or the stalk playing up Smile
Posted 6th Jan 2010 at 18:16
mabgti
NV motors
Most likely the indicator stalk mate... ive replaced mine twice over 7 years!
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 6th Jan 2010 at 21:41
shah_gti6
Cheers guys. Is there any way of checking whether this is the case? Unsure
And dare I ask how difficult is it to change over the indicator stalk...and how many notes? Dry
I don't recall seeing a FAQ so maybe it is about time I did one having been a member here for quite a few years! Smile
Posted 7th Jan 2010 at 00:17
Easy, undo the 3 steering cowl screws and remove top and bottom pieces. Then undo the two screws holding it in and disconnect connector. Dependant on your steering column position you may need to lower the column so you can slide the unit out.
Simples.
Posted 7th Jan 2010 at 00:31
