Author Subject: Random engine questions
smegal
Can someonne confirm that the bore and stroke of our engines is 86x86mm and that the compression ratio is 10.8:1
Also what is the:
Con rod length
Wrist pin offset (no idea what this is)
Also does anyone know information about the poston bowl diamiters etc?
Ex SC-6
Now in a Megane R26
Posted 6th Jan 2010 at 02:53
rich_w
Bore / stroke: 86,0 square
Con-rod length: 158,0
Gudgeon pin offset: 0,5 EX
The gudgeon pin offset is to help equalise longitudinal thrust of the piston against the cylinder walls during the combustion process.
Smile
Contact Details:
07732 822546
Posted 6th Jan 2010 at 03:03
mxcrazy
86 x 86 is correct
10.8:1 is correct as stock
rod length, centres is 158mm (s16 or 2.0 mi15 is 152mm)
standard gudgeon pin to deck height is 34mm, dont know offset
edit: too late
Posted 6th Jan 2010 at 03:07
